View Full Version : Source?
Ron LaDow
10-23-2001, 06:47 PM
Aw right. I wanted to seal a couple of parts and the sealant has dried in the cut-to-fit plastic nozzle on the tube.
Same thing happens with silicone, and I end up buying a new tube and throwing out the old one, still half full.
Yeah, I know I could clean 'em out, but...
Anybody got a source for the nozzles alone?
Thanks.
Thrud
10-23-2001, 10:54 PM
Loctite might have what you need. I use hyperdermic syringes to do fine stuff.
Paul H
10-24-2001, 11:46 AM
One trick is to stick a nail in the nozzle, instead of putting on a cap. Pull the nail out, and your ready to squirt.
snorman
10-24-2001, 07:44 PM
Sounds like a workable solution for incontinence too Paul. ;-)
To close the end of silicone tubes, I use a wire nut. Just screw it on and it forms the threads on the end of the tube.
Jim
Thrud
10-25-2001, 10:12 PM
Ron,
You are a machinist, make your own damn caps. Then tell us how to do it - we have the same problem...
Dave ;-)
charlie coghill
10-25-2001, 10:29 PM
Hay Guys
Use an wood screw eye bolt,screw it in the nozzel and when you want to use it again you have a ready made handle to take it out.
Charlie.
timmer
10-26-2001, 07:13 AM
I've been using Charlie's idea for years and it works like a charm.
Timmer
Ron LaDow
10-28-2001, 10:28 AM
Thanks, guys.
Been out of town. The screw in the end doesn't work with this sealant; it still goes off and plugs the end.
Thrud,
If I find a solution, I promise I'll report.
Ron LaDow
