I have got a major problem..I hope someone can help me..
well I made a lot of parts that are threaded on the I.D...I sent them off to heat treat and now the threads don't fit!!
The part is a cast 4140..The thread is 1 3/4-12..The bore is 1.665"..They are heat treated to 44-46 Rc...so just rethreading them is not fun...When I machined them, each part was checked with a thread gage..beautiful, i thought...But now the thread gage won't fit...The bore stayed the same diameter before and after heat treat..But the major diam. of the thread must have shrunk...right?? These threads were single pointed, because tapping is a bear, plus the cost of the tap...Is there any way I can heat these parts up so the threads will expand and stay there, without annealing the part?? To try and chase these threads with a tap will be a bear and really expensive..I would go through a lot of taps because of the hardness...any Ideas??? I have 91 parts....don't you just love problems...I sure do!!!!
thanks
brent
thanks
brent
