3jaw
03-15-2002, 02:41 PM
I am having trouble geting the motor off of a 2J Bridgeport head. I have set the variable speed to the lowest speed, removed the cover plate from underneath the motor and used the screws to try and compress the variable speed spring. That is where I run into a problem. The screws tighten up before the spring plate clears the retaining clip. I don't think they are bottoming out in the hole because I have tried shimming the screws with washers and the same thing happens. Has anyone had this problem before?
The reason that I am taking it apart is because I'm reasonably sure that the plastic insert in the variable speed cone is trashed (the machine sounds like it has a little Gremlin inside of it beating on the housing with a hammer!). Also, the upper part of the drawbar gets extremely hot after running for a while, the quill feels stiff like it is binding on something (checked for gall marks and found none, plenty of lube on it too) so I think maybe there's a bearing that is trying to seize up in the upper part of the head or there may be a problem with the splines. Spindle bearings seem fine.
This is one SICK Bridgeport. Any help would be appreciated!!!
Thanks,
Greg
Thanks,
Greg
