View Full Version : Atlas milling attachment
gunshot
05-26-2001, 09:57 PM
I have a small Atlas lathe with a 6" swing and want to get a milling attachment to fit it. Palmgren 150 is no longer made. Is there anything else I can do.
toff
05-27-2001, 12:42 AM
Hello,
Buy newest Projects In Metal! Borders has it on the shelf. Next, Sobel [surplus](long time advertiser, good service.) Or, Metal Lathe Accessories Long Time advertiser with outstanding castings.
Good Luck
toff
05-27-2001, 11:10 PM
Hello,
Good Luck
toff
Ooops "Machinist's Workshop" slow brainitis!
G.Wadham
05-29-2001, 03:41 PM
Some time ago I owned an Atlas 6 in. lathe and also needed the vertical mill attachment. The Clausing Corp catalog. # for this was M6-500.
I purchased one used from Sobel, N.J. who advertisd in H.S.M. It only needed cleaning and adjusting. Try to find one with the vise.
KenS
06-08-2001, 05:59 AM
The Brownell's catalog has listings for two milling attachments, one larger than the other. They seem generic. I don't know a thing about the things, but you could call and ask at 641.623.4000. They're in Iowa and deal in gunsmith tools, supplies, and parts.
shlimbo
06-26-2001, 01:19 PM
<font face="Verdana, Arial" size="2">Originally posted by gunshot:
I have a small Atlas lathe with a 6" swing and want to get a milling attachment to fit it. Palmgren 150 is no longer made. Is there anything else I can do.</font>
I have seen milling att. for your lathe on
Ebay. Look under "Atlas". It seems there is
one on there every 2 or 3 weeks.
gvasale
03-14-2002, 09:48 AM
try plaza machinery, bethel vt he advertisesin HSM
John Allen
03-14-2002, 10:03 AM
Projects in Metal, Is this a Mag? who publishes please, can't seem to locate using search engines.
Rgds
<font face="Verdana, Arial" size="2">Originally posted by toff:
Hello,
Good Luck
toff
Ooops "Machinist's Workshop" slow brainitis!</font>
FLPR@juno.com
03-14-2002, 06:29 PM
"Projects in Metal" no longer exists. The same publication is now called "Machinist's Workshop."
John Cranor
03-19-2002, 12:37 PM
Hi there,
I had one of those Palgrem milling attachments for the Atlas 6". I think I still have the castings. I'll look...
docn8as
03-19-2002, 06:48 PM
u do not want a milling attach that mounts on compound !!!get one that takes the place of compound & mounts on x/lide boss..trust me .....i can take a .030 cut on steel w/ mine when set up RIGHT .....
best wishes
docn8as
docsteve66
04-04-2002, 03:23 PM
docn8as was so right when he said "u do not want a milling attach that mounts on compound !!!get one that takes the place of compound & mounts on x/lide boss..trust me .....i can take a .030 cut on steel w/ mine when set up RIGHT ....."
I have a 10 inch atlas, wanted a light mill. mounted a tool holder and dial indicator and pushed it around. Near heartfailure at the readings.
Bought cuple of "angle plates" from ENCO and some 2" shafting. Cut the shafting to duplicate the center shaft on the rotating cross feed, bolted the shaft to the angle plate and cut a hole for the compound to fit its old shaft into, drilled and tapped the angle plate to lock the compound in place. I used tee nuts into the compound tool slot to hold mounting plate for my work. The compound gives me Z axis movement, the cross feed gives Y axis, and the carraige feed gives me X axis movement. The working part can be rotated around the Tee nut. Dirt cheap, and rigid. I do worry about breaking something cause it is so stiff. it wont bend before it breaks.
mike thomas
04-04-2002, 04:55 PM
I have the larger Palmgren, and agree the compound is not the place to be mounting one. I tried it, and it is too loose, floppy, and provides quite a bit of leverage against the compound/cross slide junction. Mike
Jim Wilson
04-21-2002, 09:54 AM
I have an Atlas six inch milling attachment that mounts on the cross slide replacing the compound slide. I also have the morse taper tool holder and drawbar for 1/2 an 3/8 inch tools using a sleeve for the 3/8" tool. I have recently purchased a Taig milling machine and don't need the Atlas device anymore. Contact me via e-mail and we can make an arrangement if you stil need the tool.
Jim Wilson
