View Full Version : EDM design by Langlois
captn
03-14-2001, 12:13 PM
I have the EDM book from HSM; in chapter six
Langlois suggest some modifications but gives
no component values. Can someone help me
with the identification of the resistors,
capacitors, and MOSFETs for diagram 6.8?
Thanks, the_captn
Daubie
03-15-2001, 07:28 PM
You should check out www.egroups.com (http://www.egroups.com)
When there you will probably need to sign up. After that in the lookup box put in EDM or directly CAD_CAM_EDM_DRO Also get to (on my browser I type rec.crafts.metalworking). This is a newsgroup. With pictures and an archive of 25,000 past posts go to www.metalworking.com (http://www.metalworking.com)
Over at www.delphi.com, (http://www.delphi.com,) sign up then find the Shopmaster/Shoptask Forum. In the CNC heading there are some guys I think that may be helpful.
I replied to this post previously, but it didn't post, probably something I did wrong. Don't know where it went.
Kurt
Larry Jordan
04-24-2001, 05:51 PM
You and I must be the only two who have that book. Have you found the answer to the questions you posted? Did you have any problem locating 5 amp transformers in sizes that would fit in the chassis that are pictured in the book?
Larry J
