hudd
05-14-2005, 11:57 PM
I'm intently searching for any information about the BenchMaster vertical milling machine, model MV1, pre-1980 and probably dating around 1950. I recently acquired one, and I am really need of an owner/operator manual with original specs. But any information, including pictures or suggestions would be greatly appreciated. I have been searching for awhile, and haven't found more than four items after performing every search keyword and combination I can imagine. But I definitely have the machine with the Bench Master Mfg. decal and serial number, so I know something has to be out there. I realize with such solid cast-iron construction and vintage engraving on the body that this is a much older unit and info won't be easy to find. Thanks for whatever help you can throw my way!!!
