04-05-2006, 12:22 PM
I have added to the design of my power unit I plan to build to operate my slotter/hobber.
http://vts.bc.ca/pics/ppu1.gif
It now includes a complete air cycle shuttle valve system. This allows the unit to operate either in full automatic stroke mode or in a single cycle mode. If the stroke length is set for full stroke the unit runs continuously in and out at a rate controlled by the upper needle valve.
If the stroke length is reduced to 1 1/2" or less (full stroke is 1 3/4") then the unit runs in a single cycle mode doing one out and back stroke and stopping. The green start plunger initiates each stroke cycle. Pressing the reset plunger immediately sets the unit to return stroke mode at any point in the cycle and pressing the air cuttoff and the reset together stops the action.
This drawing is partly a schematic as the actual orientation of the parts need not be as shown. The speed control needle valve would be placed to the front instead of as shown but that doesn't change the design. The entire shuttle valve assembly and air inlet would be rotated 90 degrees to place the air inlet to the rear and allow for mounting.
Although the design may appear complex it only has two main moving parts during operation, the ram and the shuttle valve (check valves excepted). The black dots represent O-ring seals for the ports. I may simplify the design a bit more by machining the entire cylinder assembly from solid.
