View Full Version : Name change
John Stevenson
04-14-2006, 07:09 AM
I have a problem folk.
First off let me show you a job I did yesterday.
http://homepage.ntlworld.com/stevenson.engineers/lsteve/files/acmescrew1.jpg
It's a 12" length of 5/8" LH acme thread and nut for a machine feedscrew.
It was screwcut on my CVA lathe in the normal manner, HSS tooling at 120 rpm.
Normally at these speeds soluble oil based coolant doesn't work well and I use a spray on Rocol type cutting fluid to get the required finish on the flanks of the threads.
Well the other day because the CVA was low on coolant I cleaned it out and swapped over to the free neat cutting oil I was given.
The difference is fantastic, drilled holes look close to reamed holes and just roughing gets a decent finish instead of plowed fields.
http://homepage.ntlworld.com/stevenson.engineers/lsteve/files/acmescrew2.jpg
Is the thread, not a good pic as daughters camera doesn't have macro but it gives a good indication of the flank finish straight off the tool.
Now the problem, because of my banter over the last few months with IOWOLF over my name, Richard the III etc, etc, I finished up with Sir John, Earl of Sudspumpwater which has a nice ring to it.
However Sir John, Earl of Neatcuttingoil doesn't so I'd like you all to come up with a neat [ no pun intended ] name.
The winner gets a free 5 gallon drum but they have to pay shiping ;):D
Alistair Hosie
04-14-2006, 07:37 AM
Hey lord snootie I always thought richard was the good king and John the bad so I will "as I am your pal" call you good sir John earl of the Islamic state of Nottinghaaaaaaam or NottingLaaamb as they don't eat haaaaam:DAlistair or with dolly should that not be Notinlamb
speedy
04-14-2006, 08:05 AM
Allthough a lesser ranking perhaps;
Sir John, Viscous Viscount of Nottinghamshire.
Ken
malbenbut
04-14-2006, 08:13 AM
Slippery John with all that cutting oil what else
MBB
SDL
04-14-2006, 09:48 AM
How About
Lord Neat-cut
Leigh
04-14-2006, 09:49 AM
John, Archduke of Acme
04-14-2006, 09:59 AM
Sir John, Earl of Lube on Toolingham.
Your Old Dog
04-14-2006, 10:27 AM
"Johnny-On-The-Spot" Other referances to outhouses (privys) would be just to obnoxious!
04-14-2006, 10:51 AM
John Stevenson,Earl of coolant pump:D
Rustybolt
04-14-2006, 12:04 PM
King John of Coolant
IOWOLF
04-14-2006, 12:34 PM
Free oil? Shipped from England I pay Shipping ?
You are so tight you will need the oil,Keep it and drink it.
Sir Tight wad,Earl of oil.
Scishopguy
04-14-2006, 12:52 PM
How about
Sir John Earl of Sliperypumpedwater
Kind of has a nice ring to it, don't you think? 8^>)
Jim (KB4IVH)
Charles Ping
04-14-2006, 03:40 PM
The difference is fantastic, drilled holes look close to reamed holes and just roughing gets a decent finish instead of plowed fields......
And I never thought that cutting fluid could make such a difference.
Surely you've been a knight long enough and are due a promotion - Lord Stevenson of Neat Oil (or maybe you haven't donated enough to Tony Blair yet.....)
Charles
Alistair Hosie
04-14-2006, 03:55 PM
Wolfie sir johns is as you state a tight wad but not as tight as his old Scottish pal as I use both sides of the toilet paper:DAlistair
John Stevenson
04-14-2006, 03:59 PM
TWICE OVER
04-14-2006, 04:10 PM
"I use both sides of the toilet paper:DAlistair"
I presume you save a roll used one side only for company... :D
Allan Dimmock
04-14-2006, 05:01 PM
Of course, come the revolution, we the people of the Free Coolant will overthrow the coolant barons and share the coolant among the common citizenry. That should give us about a thimble full each. Then we will go on to b%*ger everything else up.
Alistair Hosie
04-14-2006, 05:30 PM
I presume you save a roll used one side only for company..:D.
hey Evan not even when the Queen comes round to have her corns trimmed on the belt sander.:D and John I never use them twice over but we do seperate the sheets for reasons of thrift Alistair
IOWOLF
04-14-2006, 06:08 PM
This is was too much information on T/P.and Alistair.
matador
04-14-2006, 06:47 PM
Earl of Noteatingham?
Sheriff of Swarfingham?
Serf of Notgreenpaintingham?
Master of Machination?
I'll come and collect my drum as soon as I win the lottery:D.
Alistair Hosie
04-14-2006, 06:50 PM
Sorry Wolfie did that turn your stomach a lil :DAlistair
john hobdeclipe
04-14-2006, 07:07 PM
Why settle for all this Duke & Url stuff? Set your sights a bit higher and be the King of Kool Kut.
Allan Waterfall
04-14-2006, 07:32 PM
Yes,but you have to let the used side dry out first.:D
Allan
JCHannum
04-14-2006, 08:12 PM
If you are going to let it dry, you might as well crinkle it off and go for four uses.
We used to have to do that so we could keep the Sears catalog to order from.
Millman
04-14-2006, 08:19 PM
Outhouses and Sears Catalog. Almost a match made in heaven.......other than the smell. Some weren't ventilated very well. Those were the days, fighting spiders and snakes while things drip down your trousers. Usually bibs with rusted snaps.
TECHSHOP
04-14-2006, 09:05 PM
All this time I have been using the junk mail, and then sending it back in that nice postage paid evelope they kindly supplied.
3 Phase Lightbulb
04-14-2006, 10:33 PM
John, How old are you? Are you old enough to be:
"3 Phase Hearing Aid" ?
-Adrian
Nicholas
04-14-2006, 10:55 PM
How bout
Knight of SloppySeconds
(sloppy second-handed cutting oil, that is)
Mcostello
04-14-2006, 11:07 PM
Prince of Luck. I have seen posts of what gets dropped off, and could use several friends like that!
Carl
04-15-2006, 02:03 AM
Sir John Earl of Slick Screw
http://www.themysticcastle.com/images/smilies/knight.gif (http://www.themysticcastle.com/images/smilies/knight.gif)
Alguy
04-15-2006, 02:05 AM
how about Sir John Earl of Recycledom
3 Phase Lightbulb
04-15-2006, 02:10 AM
THAT OLD GANG 'O MINE (http://img.photobucket.com/albums/v35/lathefan/pmbb.jpg)
I hope you guys wear protection!
http://www.bbssystem.com/images/smiles/icon_lol.gif
Carl
04-15-2006, 04:23 AM
Ditto...
THAT OLD GANG 'O YOUR'S (http://img.photobucket.com/albums/v35/lathefan/ip013652.jpg)
SJorgensen
04-15-2006, 04:37 AM
It has been very fine for me to know a person who lives in Nottingham. I am a great fan of Robin of Loxley and especially the old Errol Flynn version of Robin Hood. It is fine for me to remember you in this place (even if reality doesn't fit that fantasy.)
I would call you "Sir John the Inspirer." I say this because of your message to me when I was considering purchasing my BP milling machine and I am glad of your advice and I am very happy with my decision.
Thank you Sir John the Inspirer.
Spencer Jorgensen.
Allan Dimmock
04-15-2006, 06:31 AM
Like all aristocracy, you should just stack the titles up.
Sir John, Lord of Lubrication, Earl of Sudspumpwater
Then perhaps you could sort out your motley surfs, with their arse wiping and sheep. Most unbecoming for a man in your position!
Your Old Dog
04-15-2006, 07:44 AM
We Scots sure are a boastful lot. Spring for a roll of toilet paper and feel compelled to tell the world about it :D
3 Phase Lightbulb
04-15-2006, 10:56 AM
Ditto...
Good one! Luckly I wasn't drinking any Gatorade :)
lynnl
04-15-2006, 04:10 PM
I dunno folks. To me "Earl of Sudspumpwater" seems to have a better ring than the offerings so far.
Not that I can think of anything better. I can't remember all the English titles. What else do we have other than King, Prince, Lord, Earl, Duke or Squire? ...and what's the pecking order of them all?
Hey, how about Sir John, Earl of Knurl? Yeah, I guess that's kinda weak too.
I think somehow we need to incorporate the word 'floor'.
TECHSHOP
04-15-2006, 04:16 PM
I'm not much up on the pecking order over there, but I may be so bold as to suggest:
Sir John, Tool Tart
Alistair Hosie
04-15-2006, 04:27 PM
The good knight knurledknuts:DAlistair ps gert will be after my blood now:D
Timleech
04-15-2006, 04:31 PM
Agreed
You haven't put neat oil in all your machines yet, have you, John?
Tim
John Stevenson
04-15-2006, 05:30 PM
No only a couple so far.
The last ones will be a while so I can use up whats' on stock in soluble and what comes out the others.
The Beaver CNC is going to be a bitch as it's in the foot of the machine.
charlie coghill
04-15-2006, 09:51 PM
Carl don't post any thing like that "Old Gang Of Yours" Opening that at 5:30 this morning I like to have fell out of my seat laughing. Did wake up the better half.
Carl
04-16-2006, 05:09 PM
Glad you liked it Charlie http://img.photobucket.com/albums/v35/lathefan/8e0b17be.gif My apologies to your wife.
billyboy
04-16-2006, 08:19 PM
nowthen sir john, sorry i havent been intouch for a while mate but ive had some problems with the old ticker, everythings fine now.
how about ermm lets think!!....sir john the 1st knight of the round rotary table
love ya me lord!
bill
