View Full Version : Harrison Lathe Bearings
Shuswap Pat
04-30-2006, 01:38 PM
I am trying to find some repalcement bearings for my 13" Harrison Lathe. They are FBC brand, made in England. I am looking for a matchup for a MS11 - 1 1/8 bore, and a MJT 1 1/8. Any suggestions.
Pat
Peter N
04-30-2006, 03:38 PM
If you know the OD and the width/height as well as the ID then any good bearing stockist should be able to match them for you. I'm guessing they are too old to have any modern reference numbers stamped on them?
FWIW this link http://simplybearings.co.uk/shop/mjt1-imperial-single-deep-angular-contact-ball-bearing-286x714x206-p-5023.html has an MJT 1 1/8" (ID) but IMO they are far too expensive to buy from:)
Peter
Timleech
04-30-2006, 03:43 PM
You don't say where you are, but I would have thought a good bearing house anywhere would be able to tell you what locally available equivalents are. I have a feeling MJT are a split thrust bearing, if so it might be a bit hard to find and expensive.
Tim
quasi
04-30-2006, 03:57 PM
Pat
If you are truly living in -around the shuswap area, try a bearing supply house, perhaps in Kamloops? if not Calgary has several, and of course Vancover. Measure your bearings metrically to minimize the confusion.
John Stevenson
04-30-2006, 04:15 PM
MS and MTJ series are Imperial bearings
Shuswap Pat
04-30-2006, 09:23 PM
Thanks for the info gentlemen. I haven't been able to cross match these with the NTN, SKF, and FAG catalouges I have. Any body got any suggestions for Canadian suppliers?
Pat
motorworks
04-30-2006, 09:45 PM
"suggestions for Canadian suppliers"
Perhaps the best supplier in Canada is Kinecor
See:
http://www.kinecor.com
Take careful measurements and give the measurements along with any bearing numbers etc to Kinecor and they should come up with the correct bearings for you.
take care
eddie
Mark McGrath
05-01-2006, 05:07 AM
The MS11 bearing cross references to FAG MS11, NH MS11, RHP MJ 1.1/8",
RIV PB-9, SKF RMS-9, STEYR RMS9.
Google has the answers.The MJT 1.1/8" bearing is an angular contact,2.13/16" O.D.,13/16" wide.
Mark
Charles Ping
05-01-2006, 06:05 AM
Mark
By odd coincidence the same as used for the front main bearing of a 1930's Austin Seven.
Charles
