View Full Version : Bandsaw Coolant
michaelj
02-10-2003, 08:14 AM
What's the concensus on the best coolant to use with a bandsaw? I'll be cutting mostly cold rolled.
Thanks
02-10-2003, 10:44 PM
I use water soluable oil with a flood system it will work with most things as you can adjust the amount of oil depending on material conditions feeds and speeds.
[This message has been edited by wierdscience (edited 02-10-2003).]
Thrud
02-10-2003, 11:59 PM
Michael
I would suggest that you get a good synthetic for all of your machines. The synthetics when mixed properly are extremely cost effective and provide excellent lubrication to the cutting edges. They have less tendency to go rotten like soluable oil products and produce less mess and easier cleanup. An small aquarium pump bubbling through the coolant will prolong its life by increasing oxygen content.
