View Full Version : My un-lurking contribution
applescotty
05-09-2006, 12:48 PM
Gents,
I don't have many nifty projects to show like some of the recent posts, but I'll submit my lathe center height gauge for my minilathe for your comments. I used an engine valve for the base/stem, and just turned the collar to go on it. Note that there's a second collar sitting on top of the first. The top collar was the first one I made, and I rushed through drilling the hole for the setscrew, and managed to snap off the tip of a center drill in it. So, I keep it on there to remind me to slow down and do things right so that I don't have to do them over. :)
Sometime I'd like to add an arm to the collar, so that it would be easier to measure the height of the lathe tool, but this works for now.
http://i4.photobucket.com/albums/y141/applescotty/tools/center_height_gauge.jpg
applescotty
Ausserdog
05-09-2006, 01:39 PM
That's a cool simple way to build one. Now I know what to do with the 'spare' valves kicking around the shop. Thanks for the great idea.
Schutzhund
05-09-2006, 01:42 PM
Slick idea applescotty. Thanks for sharing that.
IOWOLF
05-09-2006, 05:42 PM
This is what you need for those broken center drills. Drill around the nose and it is saved.
http://img.photobucket.com/albums/v11/iowolf/SANY0200.jpg
big-dipper
05-09-2006, 11:23 PM
best to use a center drill for making a lathe center, and use a spot/spotting drill for drilled holes. You'll be much happier in the long run. ;)
