View Full Version : Post #2
charlie coghill
05-10-2006, 10:38 PM
Ok, these are of a sandblasting cabnit, using about 16 gage metal, that I built some years ago.
The first pic is of the interior, there is an expanded metal floor that the job rests on. The wall that is inside on the right is a baffel to stop the grit from being sucked out of the machine and still will let the dust exit the cabnit.
The baffel hanges below the floor about 8 inches
http://img.photobucket.com/albums/0903/kcprecision/Sandblasterinteriorview.jpg
This pic is the front if you haven't guessed.The gloves are place over and held to rings with long hose clamps.
http://img.photobucket.com/albums/0903/kcprecision/Sandblasterwindowview.jpg
This how the hopper is shaped, at the present I have to drain the hopper into a bucket and pore the sand back into a HF type of sand blaster, I did try a siphon feed with the sand but I guess I did not have enough CFM or pressure. I now have picked up a compressor that is run by a 4 cylinder contintial engine so I think that I will try the siphon once more.http://img.photobucket.com/albums/0903/kcprecision/Sandblastersandcollectinghopper.jpg
This is the vacume fan that I will be using now, the orginal fan was powered by a 1/3 hp motor and it did not remove the dust well enough. The glass would cloud over and you would not be able to see what you were doing.
http://img.photobucket.com/albums/0903/kcprecision/Sandblastervacumefan.jpg
And I will do another post.
pcarpenter
05-11-2006, 01:50 PM
Charile-- regarding the siphon problem, someone here posted a tip when I grumbled about my cheap HF blast cabinet having problems siphoning media. I didn't have the issue with glass beads, but it appears to be a friction problem with Al oxide. The tip was to braze a washer over the opening in the metal pickup tube that sits buried in the "sand". I have not tried it yet, (haven't had time), but it makes sense as it should prevent the stuff from packing itself in the tube. Someone else chimed in and said it works on theirs.
I just wanted to offer the tip as being able to siphon the stuff instead of having to drain it and pump it back into the cabinet should make a lot less mess.
Paul
PS. Hope that blower does not have so much suction that it starts picking up sand :-) I think it would not last long if it gets sand in it.
