View Full Version : Playing with the new RT
Wareagle
07-18-2006, 05:45 PM
http://i60.photobucket.com/albums/h15/wareagle1771/100_0287.jpg
http://i60.photobucket.com/albums/h15/wareagle1771/100_0315.jpg
Results from playing with the new RT. I am building a finger engine for a 'filler' projectl. I had to break down the set up to do another quick project. I hope to get back on it soon to wrap it up.
In case someone is thinking it, a lathe would by far be the better choice for this application, but I can't seen to locate one in my shop! :D
rockrat
07-18-2006, 06:05 PM
Arent they fun! Just think of all the cool things you will be making for your buddies that dont have one. There will be a line at your door soon.
rock-
07-18-2006, 07:58 PM
Is that a Phase II? If so do the table locks really lock?
I've been wanting an 8" because the 12" I have takes up too much room on the mill and it's to freakin heavy.
And yes they are fun:D
CCWKen
07-18-2006, 08:14 PM
Darin, them twelve inchers are hemorrhoid makers. :D :eek: The RT's that is.
Did you do the recess on the mill too? Great work!
jdunmyer
07-18-2006, 08:44 PM
WS,
I have an 8" PII RT and have been quite happy with it. The table locks seem to hold just fine. After I bought it, I also got the tailstock and dividing plate set, but have never needed either (so far!). Have used the table quite a bit on a couple of model engine projects.
I did have a problem: was milling a round-bottom slot with a ball-end mill and the thing was chattering a bit, causing back-and-forth vibration in the table. "Something" caused the thing to gall up, and I had to disassemble the table to clean up the boogers. Getting it apart was easy, once I figured out that the table locks had to come apart first.
07-18-2006, 08:52 PM
WS,
Did you notice any casting sand or other foul material inside?I had an 8"India made unit that was full of sand and CI chips:eek:It has been converted into a welding positioner:D
07-18-2006, 08:54 PM
Boy,the "things" some people know about here:rolleyes::D
rockrat
07-18-2006, 09:05 PM
I have been told that hauling around "My big 10 inch" would make the girls go nuts. I cant imagine what a 12" would do.
Sorry, had to be said.
rock-
Wareagle
07-18-2006, 10:22 PM
Yes, it is a 10" Phase II table. The locks seem to hold, though I haven't really 'loaded' it yet. It is real smooth, and there is very little backlash. In my opinion, it is a good table for the money, and it should serve me well for the things I do.
CCWKen, I did the recess with a 1/2" end mill, and then used a 3/8" ball end mill to finish the recess. Afterward, I spot drilled seven places to bore holes into it at a later time.
Unfortunately, I was volunteered (got to love that!) to build two small two-wheeled dollys for my son's school, so I have had to slide the flywheel back in line for a bit. Oh well, I know the kids will have fun with them!
smagovic
07-18-2006, 10:31 PM
CCW they are not hemorrhoid makers they hernia makers. Hernia you get in the front, hemorrhoids you get 'somewhere' in the back, ha ha. I am not sure we spell it right, but we know what we are talking about, don't we. Vic
andypullen
07-19-2006, 07:29 AM
Where'd you get it? I need a H/V RT.....
Andy Pullen
Millman
07-19-2006, 07:40 AM
{. Hernia you get in the front, hemorrhoids you get 'somewhere' in the back,} Tell ya what, when you catch and hold over 1000 lbs. of steel to keep from getting crushed and disemboweled at the same instant; that causes alot more problems than those 2 , even those are included. All it takes is 1 stupid person in a hurry , on a forklift turning a corner, when you see it coming, you will catch it instead of being crushed. I still remember his astonished fear, thought he had killed me. The degenerative part is what gets you.
kap pullen
07-19-2006, 08:08 AM
I have always found rotary table work to be fascinating.
To see and end mill machine a curved surface on a rod end is a satisfying thing.
I had a precision taper bored hole in an odd shaped plate to do in a job.
The lathe faceplate with counterweights was a pia. I set the mill head over with a sin bar by tramming, and indicated the pre-bored hole in on the rotary table.
A carbide end mill did a quick and accurate job.
On my 3 pound cannon, I milled the wheel fellows (42” wheels) to true them up on the old 8” rotary table I had.
I have spoked out many gear blanks, train wheels, cut teeth, made dog clutches, bolt circles, radial, and angular holes for various projects over the years.
I don't use it every day, but when I do, I get a special satisfaction from it.
Good accessories for the rotary are a three jaw chuck, sub extension plate with lots of threaded holes, a threaded plug to press fit under the table for center clamping, and a system of centering pins to locate from the center hole of the table.
Below is machining the trunions on a mini. Swivel gun on the rotary table with a three jaw chuck.
http://img.photobucket.com/albums/v206/kappullen/throtary3.jpg
Kap
Millman
07-19-2006, 09:07 AM
Kap, what I can see of it..that is one nice set-up. Wish you had a bigger pic.
jdunmyer
07-19-2006, 10:39 AM
WS,
I didn't really notice any casting sand in the unit, but that's probably what caused the galling, as it did seem to be lubricated well enough.
It's not something that I use a lot, but there's times that nothing else (in MY shop!) will do.
07-19-2006, 08:15 PM
Yep,same here,I might need to use one every other month,but like you say it's not easy to get around it.I just hate swinging that 150lb monster around for one or two parts.
ProGunOne
07-19-2006, 08:44 PM
I thought you were talking about on of These
http://img88.imageshack.us/img88/4967/mjm90rtpiggypackeryq9.jpg (http://imageshack.us)
