mjm
07-23-2006, 11:58 AM
I purchased a used Lagun 310 a couple of years ago and stored it at a friends shop. It's time to get it running. My friend determined that the 15volt biased power supply on the servo side was not working/burned up. He found a "used" one laying around and installed it. The machine performed nicely but the 15volt biased power supply on the servo side burned up shortly after installation. He has found a new 15volt power supply but we are wondering what is causing the power supply to burn up on the servo side. Do we need to go further downstream of the 15volt power supply? Could a bad servo be causing the problem? I don't have direct access to the machine but I can get more info as needed. Thanks for any help, mjm
