View Full Version : Taper Attachment.... need help
John R
07-30-2006, 12:00 PM
I'm trying to mount a Grizzly model H5949 taper attachment to my Grizzly 14 x 40 model G0554 lathe. It seems to need for the rear bearing mount on the cross slide screw to be removed and then the screw with its two trust bearing be mounted to the taper attachment. Problem is that the rear thrust bearing will not fit in the spece provided.
I hope to find some kind person who has already solved the problem and will share his experience .
