View Full Version : Odd sized angle iron
Gary Reif
08-04-2006, 10:35 PM
Has anyone noticed angle iron to be odd sized lately? I don't make a habit of checking dimensions when we get a shipment in but it was brought to my attention this week. Since I maintain the inventory of steel at work. One of the guys asked where I was getting the odd sized iron. So I go measure some of the angle. The 1-1/2x1-1/2x1/4 measured 1.436x1.520 or so, and the 2x2x1/4 was like 1.980x2.015 or so. I do know we have got some from a different scource at times. This can be quite an issue if you are not aware of the difference. Seems like when I usually measure with a tape in the past while building a stand or something it was a lot closer then that.
Is this some second steel or what?
Thank for any thoughts on this.
Gary
CCWKen
08-04-2006, 10:48 PM
I don't know where your supplier is getting theirs but mine comes from Mexico or Turkey. :eek: That may be the reason for the odd sizes but mine stuff has been pretty close. I'd tell the supplier to come pick up HIS scrap or make a discounted offer. Check the weight of a section and if it doesn't match up, tell them to come and get it.
bob101
08-04-2006, 10:58 PM
That's well within mill tolerances. Structural steel is not that exact. There are acceptable limits for sweep/bow/thickness/ and differences in the L size and those are well within those.
Put a mic on plate and you'll see a big difference from coil to coil - or even one end of the coil to the next.
08-04-2006, 11:41 PM
You wouldn't believe some of the stuff that comes in from the mills.
We had 8" channel that measured 7-1/2" on one end and 8-1/4" on the other,3x3x1/4 angle that measured 3x3 on each end,but 2-3/4x3 in the middle.
It's normal for angle to be +/-1/16",that's why the art of structural steel layout exists,thats also why you layout from the heel of the angle and not the edge.
Leigh
08-05-2006, 10:51 AM
And what tolerance is specified on your Purchase Order?
If, as I suspect, there is none, then the vendor can provide whatever he chooses.
