View Full Version : Plans full auto co2 bb "usi" submachinegun
Mortimerex
08-07-2006, 05:19 PM
Anyone interested in plans for a full auto bb submachine gun with the following specifications? (The prototype isn't quite complete yet so the specs aren't locked in)
30 round mag (finished) ,230 round drum mag (in progress)
approx 3-6 round/second
approx 400fps velocity
uses standard bbgun 12g co2 cartridges
barrel - approx 12" actual (beyond the firing chamber) made of ultra low coefficient of friction materials.
very simple and robust design easily machinable with mini mill and lathe. Has about half a dozen moving parts. Most of it can be machined from acetal (plastic) or other materials of moderate mechanical properties.
Drawings include exploded view assembly drawings with parts lists, detail drawings, and graphic illustrations. And the details can be in either U.S. or metric units. No plans for foreign languages. I'm not soliciting this as I didn't really plan to release these drawings and designs at all.
Almost got the design complete and have a prototype and was wondering if anyone is interested or has done something similar. I'm a bb gun nut by the way. I was just planning to auction these on e-bay as hand crafted custom machined low volume production (made by myself working like a dog) - sold-to-the-highest-bidder-thing.
Heres a brief glimpse. I've cruelly marked out details so hopefully my prospective patents won't be infringed.
http://img.photobucket.com/albums/v159/DirtyHairy/usi_mk1.jpg
http://img.photobucket.com/albums/v159/DirtyHairy/bm30mag.jpg
If this works out, I plan to move on to making full auto bb gun carbines using the new bigger co2 cans. Hehehe!
lynnl
08-07-2006, 05:59 PM
Do you suppose it'd disable a rabbit in a man's garden at a range of ..., say 30-40 yds?
What sort of velocity does a regular BB gun shoot anyway? That 400fps sounds kind of slow.
I can disable 'em with a pump-up Crosman. (when I hit 'em that is) Enough to move up and finish them off. Tho I'm usually shooting pellets.
But that full automatic might tip the scales more in my favor for the initial hit.
hornluv
08-07-2006, 06:27 PM
That's pretty darn cool. I remember always trying that one contest at the carnival where you had to shoot out a little star on the target with a full auto bb gun. I think you got 100 rounds to do it. I guess the gun was run off an air compressor. The trick was to shoot around the star. Everyone assumed you had to completely obliterate the star from the middle out and that never worked. Do any of you remember that game, or was it something unique to the Crab Festival in Lacombe, LA?
Stuart
rockrat
08-07-2006, 06:48 PM
Looks good to me. Would make a fun project.
rock-
Mortimerex
08-07-2006, 07:03 PM
Stuart
Actually, that was my inspiration. Except as I recall, the carnival in my area had tommy guns running off an air compressor but they only had like 10 or 20 shot magazines and the goal was to shoot off a rubber duck (weighted with lead shot of course) and I suspect the inner barrel was bent or out of line and the sights adjusted so your first shots hit about 4' from the target.
The best small cartridge co2 bbguns have only a little over 400fps velocity, the lowest I've seen (but ironically the funnest to shoot) is the Walther Crosman PPK at about 250fps which half its charge goes to power the realistic kickback of the steel slide (which weighs more than my whole gun). There are custom over $200 single pump, single shot bb guns that go over 1000 fps but my goal is to shred paper targets (or aluminum soda cans, etc) with blistering rate of fire. I imagine those 1000fps bb guns take an armstrong approach to pump up. The standard 10pump type bb guns reach about 600fps at 10 pumps I think but don't recall exactly.
Anyway, my goal is massive rate of fire (buy bbs by the pound) not massive fps. With the larger co2 cans coupled with longer barrel lengths in my upcomming carbines (muzzle velocity is a function of barrel length and psi in an air gun for the most part) we may see an order of magnitude increase in muzzle velocity with similarly high rate of fire.
flatlander
08-07-2006, 07:07 PM
hornluv,
We played the same game at our state fair in Hutchinson, Ks. 36-37yrs. ago. The guns in the booths there were modeled after Thompson submachineguns. I think they were using #7 or #7-1/2 soft lead shot in them - if it'd been steel shot, there'd have been shot bouncing back at all the rubes trying to impress their girlfriends. I've often wondered where all those neat old subgun airguns wound up; it'd be fun to take one apart and get a good look at the mechanism.
Mortimerex
08-07-2006, 07:08 PM
Thats odd, the rabbits around my place prefer to eat the grass but I didnt plant any carrots or lettuce this spring. I wouldn't use any bb gun on rabbits, use a 22 caliber firearm, shotgun, or a bow with the wieghted rabbit clobbering head that makes the arrow stick in the ground and stand straight up when you miss- which you will probably do alot of.
Mortimerex
08-07-2006, 07:14 PM
hornluv,
They're probably illegal now (for carnival or residential areas) which is why I plan to sell them on e-bay. The mechanism can be quite simple if you understand the physics. Its not alot tho, only about 6 pages of calculations describe most of what I expect to happen. The 400fps is based on 100psi air compressor which I plan to do initial tests with. Don't know how many psi the cartridges have but I suspect it may start out producing like 600fps muzzle velocity and drop as the cartridge discharges.
Nick Carter
08-07-2006, 07:23 PM
Have you seen this:
http://makarov.com/drozd/index.html
IOWOLF
08-07-2006, 07:34 PM
I will stick to the easy ones....
http://www.burntlatke.com/bb.html
Both of yours have a small, limited BB supply. This design,is only limited by your own design,and weight restrictions.
As for air supply,a 5# co2 fire extinguisher regulated is fine.
I have owned the Lark, Drozd, and others from various mfgrs.
Mortimerex
08-07-2006, 07:36 PM
Have you seen this:
Nice but I bet that has about 10x more parts than mine. Also, my design is fully mechanical. Don't see any price on it. Even hand crafting, mine should be around $200 each (to pay me minimum wage). Hopefully selling in small quantities on e-bay the price for mine may go alot higher. Also, you don't know who designed and makes that Russian gun. Doesn't mean its not good or bad, just that you know mine was designed by an engineer with a Bachelor of Science in Mechanical Engineering (from a top 10 engineering university - top 10 in the world.) I was hoping I was the only one working on something like this. Oh well. I'm still going to finish mine (about 2 weeks) and at least try selling one on ebay. If the gun works well but selling it doesn't work, I may make the plans available for a small charge.
IOWOLF
08-07-2006, 08:37 PM
Well, now that you have crossed the line....
THERE IS NO SELLING OF PERSONAL STUFF HERE!
I wouldn't have said a thing about it, But without even seeing the other gun you think yours is better.Thats not what we are about here.
Mortimerex
08-07-2006, 09:42 PM
Haha, I'm not selling anything here. You guys are too cheap. If it don't sell at all, then I may give the plans "as is" which is what I used to actually build it. The only charge would be if you want me to clean up the drafting so it looks pretty enough to satisfy a moderately leanient drafting instructer (which I was once at ITT- not my alumni just where I worked as a drafting & design instructor while working on a Masters degree I never finished).
I do have a design remarkably similar to that Russian one, even with similar placement of mechanisms and with an electric motor too. But it was for a thompson "tommy" looking carbine size machine gun (although actually it looks sort of like a cross between a tommy gun and an m4 carbine). I want to try out the simple, small, purely mechanical, submachine gun first, only problem is my mini-mill & lathe may not be up to making the only 3 tolerance (and friction) critical parts in this design. In which case I will probably just go with the tommy gun.
If I could mass produce the "usi" submachine gun (acctually was gonna call it the "Box Mag" first for obvious reasons -but I put a little 2hand grip and milled a few cuts and it now looks remarkably like an "uzi") I may theoretically be able to sell it for around $50 depending on the difficulty of making those few critical parts. This is theoretical, as I don't plan to mass produce anything unless I can get some high bid wars going on e-bay.
I may mention it here if one sells for some preposterously high amount just to gloat tho. :D
slayer666
08-07-2006, 09:56 PM
I'd be interested.
tsmartin_98
08-07-2006, 10:20 PM
Yours looks better than the ones my friends and I bought back in the mid 70's I think. They were pretty cheesy and not well constructed but they were cheap. I can't remember how much they were but we bought a lot of them.
We soon ditched the CO2 cartridge for a 120 psi air compressor. You'd go through 500 BBs in the blink of an eye but it sure was fun while it lasted.
TS
Nick Carter
08-07-2006, 10:21 PM
Better make it an airsoft then, Ebay doesn't do BB guns:
Prohibited and Restricted Items> Firearms, Weapons and Knives:
BB Guns, Replicas, Blank Guns and Imitation Guns: eBay does not permit the sale of BB guns, air guns, black powder guns or muzzle-loader guns, and does not allow sellers to use the term “BB gun” in the item title or description of any listing. eBay permits paintball guns, "airsoft" guns, and replica, "look-alike," and imitation firearms under certain circumstances. These items may only be sold domestically in the United States provided that they have clear markings permanently affixed to them (commonly a blaze orange plug inserted in the barrel), and must not be readily convertible to shoot a projectile. This includes replicas/imitation guns of any age, as well as toy and cap guns. These items must be located in the U.S., offered only for domestic shipment and the seller must be located in the U.S. These rules apply to all items designed to look like firearms. Most states require that purchasers of airsoft guns be 18 years of age or older.
lazlo
08-07-2006, 10:50 PM
Very neat! That reminds me of the old days at the carnival where they would have full-auto BB guns, and you would get a prize if you completely shot out the black bull's eye. Of course, no one ever did (at least, no one I knew ever did), but it was sure fun spending a lot of quarters trying :rolleyes:
I'd definitely be interested in purchasing your plans, if you're confident the prototype works ;)
Edit: sorry hornluv -- didn't catch your post. Yep, we had them on the Wildwood Boardwalk back in the 70's. Looked like Thompson submachine guns like flatlander described.
Mortimerex
08-08-2006, 03:07 AM
So no ebay for bb guns:p Well, something similar. I'm sure there is some e-bay type setup that isn't run by anti-bb gun nazis
Mortimerex
08-08-2006, 03:12 AM
TS
Sounds good. I wish I'd got a tommygun back when they were around, even if they were junk. My prototype has both c02 and an npt air compressor inlet although I was planning on ditching the npt after it goes gold. It will be in the plans so you can put it in or not.
Mortimerex
08-08-2006, 03:22 AM
Within about 2 weeks I will be confident -that it either works as intended, goes back to the CAD lab, or gets trashed. Its starting to come together fast now. The design is 95% done, just need to put in a safety and finish up the trigger assembly, and detail the speedloader. Then if it works good with the 30 round box mag I gonna go ape on the 300+ round mag (which isnt nearly as big or awkward as you might think for a drum mag- a little smaller than a cordless drill battery pack).
An update on the muzzle velocity. I don't have any instruments to actually measure that but based on calculations (neglecting friction) v= 760fps. I ran the calculations on a Daisy Powerline XT which I measured barrel length of approx 4" and a claimed v of 410fps, I got 536 fps at 100psi. So friction, pressure, or barrel length measure error gives a -23.5% efficiency. So I "corrected" the usi v by that amount to get approx 580 fps. Thats probably as close a result as possible for some time.
Mortimerex
08-18-2006, 03:52 AM
Heres a link to something similar functionally to what I'm working on.
http://www.bloomautomatic.com/bbmg
Cost is over $250 and it doesn't even look like a gun at all. Looks more like a something you pound in the ground or attach to the toilet plumbing. Haha.
I redesigned my "usi" yet again reducing number and complexity of parts. This is alot closer to a final design, probably won't be any more major changes now. Even with all the effort to keep the design simple and sturdy it still takes time to machine it all. Of course, if it works like expected them I can try molding parts once I'm sure everything checks out. Several assemblies consisting of 3-10 parts can actually be made as a single molded plastic part requiring only parting line sanding and minor clean up with no machining at all.
Finished the new 30 rd removable box magazine today, may show some pictures but its basically just a box machined from acetal plastic. I found that using a coarse end mill provided a very nice non-slip grip surface, I wonder if that surface texture will transfer to the molds? Would be nice not to have to machine any more mags, just mold em by the dozen (perhaps out of recycled soda plastic even).
Also, started on the drum magazine design.
http://img.photobucket.com/albums/v159/DirtyHairy/usi_frame.jpg
It looks like I can make a 100-200 round drum mag that is actually less cumbersom than the 30 round box mag. One drawback to using the same design that the box mag uses is that there will be around 20-30 rounds that never leave the clip, but that is a minor defect considering it will increase the overall magazine capacity (without having to redesign the whole gun) so much without having the drum magazine in too awkward or cumbersome orientation.
Wirecutter
08-18-2006, 01:51 PM
My younger brother had one of those CO2 powered automatic BB guns - .177, IIRC. It was a hoot to shoot, and could really hose and area down with BBs, but the worst injury it could inflict was probably to sting or welt bare skin. The kids would put on safety glasses and a raincoat and shoot each other until the CO2 ran out.
I still remember slipping on the BBs all over the garage floor.
-Mark
