What advice do you give to new machinist when breaking them in? Myself I tell them that they have to read the machinery, read the tools, and read the material. They kind of look at me puzzled but I explain to them that they have to read it like a book. Learn the characteristics of the machine. When you learn the characteristics then you know what that machine is doing if someone else is on it or if it is running with your back turned. Know what faults the machine has. Backlash, etc. Then you know how to compensate for it. Read your tools. Then you know what or what not the tool is capable of. How much will an endmill flex. What happens when it flexes? Read your drill. What makes them cut? Why does a tool cut better one way than another? Read your materials. Why does this type of steel cut better than this type? Cut it at high speed, cut it at low speed, play with it to learn what it does with different variables. Once they learn how to read all three then the compensation falls into place. When one of my co-workers are machining a part I can tell what mistakes they are making from across the room just by the sound of their machine. Quite a few people take machining for granted. This is a cutter and it cuts metal. I look at machining as an art form. Taking a raw block of metal and turning it into a workable, functional piece. One thing I will always remember when I was broke in as a Modelmaker. The older gentleman told me to get some material and cut away everything that doesn't look like the print.
Kevin
Kevin
