View Full Version : Griptru chuck question.
Malc-Y
09-18-2006, 08:44 AM
I have just bought a new Pratt-Burnerd 10" 6 jaw Griptru chuck for use on my Colchester Triumph 2000 lathe (£165, is this a bargain or what!!!?) It appears to have been sat around in its box for some years a has very slight surface rust on the back and is complete with both sets of jaws and key. Unfortunately there are no instructions with it and I am not familiar with Griptru chucks, so my question is what is the procedure for adjusting them? I'm sure it is a simple procedure, any help will be appreciated.
Malc. :)
JCHannum
09-18-2006, 09:19 AM
The chuck has four set screws at the rear of the chuck body that bear on a spigot on the backplate. These are used to adjust the chuck as you would a four jaw.
Loosen the socket head screws that hold the chuck to the backplate, these are the six screws on the OD of the face of the chuck.
Chuck up a piece of stock of the desired diameter and indicate it as you would with a four jaw. Using the four set screws, you can dial the part in. It is the opposite of a four jaw as you are moving the chuck, not the part. Once the part is dialed in, tighten the mounting screws.
These chucks are intended for fine tuning for a specific diameter, and may not offer the same repeatability with a different diameter of stock. They typically offer adjustment in the range of +-0.010" - 0.020".
Congratulations, that is a good buy for an excellent chuck.
Timleech
09-18-2006, 12:05 PM
My griptrus are not adjusted that way. I'll see if I can find the instructions & scan them for you.
Tim
JCHannum
09-18-2006, 12:23 PM
I think Grip Tru refers to the 6 jaw feature, while the adjustable PB chuck feature is called Setrite. The Setrite adjusts in the same manner as a Buck and other similar chucks as described.
BTW, a 2year old catalog price for the 6" 6 jaw Setrite is $1091, plus an additional $200 or so for a backplate.
Timleech
09-18-2006, 01:22 PM
Try
http://web.onetel.com/~duttondock/Pictures/griptru-1.gif
and
http://web.onetel.com/~duttondock/Pictures/griptru-2.gif
Sorry I didn't manage to persuade the butler to iron it first :rolleyes:
I've been quoted £125 for a set of inside jaws for a 3.25" griptru, so that is a good price.
Tim
JCHannum
09-18-2006, 01:44 PM
Interesting, I have not seen that style before. It appears they have taken the simple and made it complex.
Timleech
09-18-2006, 02:32 PM
It's certainly not new, I've got three of various vintages, one could easily be 50 years old, same style.
Tim
Forrest Addy
09-18-2006, 03:14 PM
Regardless or exactly how it's set-up, your lastest acquisition is a dandy chuck but fragile. Use it only for second operations involving light cuts. Do not use it for general purpose machining especially for parting off. Breaking a tool or ripping the work out of the jaws is a good way to cause permanent (but not instantly apparent) damage to a three jaw chuck. I refer to damage such as splayed jaws, deformed scroll, or damaged body. For this reason you should preserve your new adjustable three jaw for best and highest useage.
Malc-Y
09-18-2006, 04:20 PM
The chuck is a 6 jaw, not a 3 jaw, so I assume that it will give a lot better grip on the work. The Pratt-Burnerd Griptru chucks are made in 3 or 6 jaw versions in sizes from 5" to 12" diameters and 3 jaw only in 3" and 4" diameters. It certainly doesn't look or feel fragile, it weighs 81 lbs! and that is without a backplate! For heavy work I usually use the 4 jaw independent and true the work with a dti.
Malc.:)
Malc-Y
09-18-2006, 05:05 PM
Try
and
Tim
Thanks Tim, this is exactly the information I was looking for.
Malc.:)
