View Full Version : OT: So, you think you are pretty smart???
Wayne02
10-27-2006, 04:26 PM
You might be startled to find out you are not as smart as you think you are...
Here are two pictures identical to each other, you have to find three differences. If you can find three differences, then you are part of an elite group of individuals.
This has been tested on 8000 people, and only 750 people out of 8000 found the three differences.
There is no trick, all three differences exist. Try it!! click on the link:
http://members.home.nl/saen/Special/Zoeken.swf
topct
10-27-2006, 04:42 PM
Thanks Wayne, :D:D:D
Weston Bye
10-27-2006, 04:52 PM
Try looking at as a stereo image. Get real close to the screen.:eek:
10-27-2006, 04:59 PM
Bah. They aren't even close to being the same. I use a special eye trick where I cross my eyes to find the differences and using strong glasses get as close as possible. To confirm they are really different I copied them into Paint Shop Pro and overlaid the two images. I then mathematically subtracted for the difference. What shows here is the result. Anything in this pic represents pixels that are different between the two images. You can tell with just your eyes if you study it closely for a while.
http://vts.bc.ca/pics/diff.jpg
john hobdeclipe
10-27-2006, 05:00 PM
Well, I'm smart enough to realize that I'm not nearly as smart as I think I am. Nonetheless, I'm still smart enough to figure out that if the two images are identical there probably aren't 3 differences.
John Stevenson
10-27-2006, 05:10 PM
Good likeness of you with your eyes crossed :D
tesswalker
10-27-2006, 05:35 PM
That's an understatement. Thank goodness my ceiling fan wasn't on.
Tess
10-27-2006, 06:13 PM
Ever heard of "deadpan" John? :)
Forrest Addy
10-27-2006, 07:28 PM
I found four differences. Did I did it wrong?
Doc Nickel
10-27-2006, 08:38 PM
-Yes. That's a strong indicator of very-late-onset adolescent dementia. There's no cure, but the symptoms can be treated by a regular application of a triple malt administered orally and in large doses.
Doc.
john hobdeclipe
10-27-2006, 10:29 PM
Yeah, I've heard of that. Is that what this is? Did I miss it completely? Maybe he's right. Maybe I'm not as smart as I think I am. :confused:
10-27-2006, 11:36 PM
I got "Install failed" three times and they were all exactly the same:D
