I need to build a large bearing spindle housing out of 6061. The bearings will be steel. The bearing races are going to be pressed into recessed areas in the 6061. Is this going to cause one of the metals to react? If so, is there anything (like sealants or coatings) that can be done to reduce this? Does grease increase or decrease dissimilar reactivity?
Thanks,
Eric.
Thanks,
Eric.
