View Full Version : first prototype
Elninio
11-04-2006, 06:06 PM
first prototype - if i had the chance to do it all by myself it would have turned better..
http://i111.photobucket.com/albums/n122/elninio123/final.jpg
http://i111.photobucket.com/albums/n122/elninio123/Nov0320060003.jpg
http://i111.photobucket.com/albums/n122/elninio123/Nov0320060002.jpg
http://i111.photobucket.com/albums/n122/elninio123/Nov0320060001.jpg
check out my photobucket for previous pics...
john hobdeclipe
11-04-2006, 07:04 PM
Hey, that looks great!
kap pullen
11-04-2006, 07:29 PM
Elninio,
That's nice work and even nicer photos.
Kap
topct
11-04-2006, 07:33 PM
If properly displayed in some kind of cheap bubble pack........who knows?
I would eliminate the close up photos for any advertising.
Now tell us the truth. This piece is off of a K-Mart special. Right?
sidegrinder
11-04-2006, 08:23 PM
Very cool! ( I REALLY like shiny metal thingamobobs!!!)
DeereGuy
11-04-2006, 10:10 PM
Not sure what it is but looks like a lot of really precise work went into it. Good job!
Your Old Dog
11-04-2006, 10:24 PM
Nicely done! Say it took onlyl 10 minutes to knock that out? :D Looks like a lot of setup time involved.
Elninio
11-05-2006, 10:13 AM
well i'd like to think its a precise piece, just because according to the dials and everything i was approaching it precisely. Actually the aligning went really quick, i think my dial indicator is infused witht he precision of the GODS! When i was setting up the piece and the vise to be square, twice i managed to get it perfectly square (by chance) before testing it with the dial indicator. The grooves arent actually that bad irl. Its not a kmart special u wont see any engraving or tags on it! Yesterday i sharpened a cutter for my fly cutter with a large cutting point radius, then tested it. I was so pleased with the results that i decided to "heat treat" it (crazy? or stupid? you decide!). Its cutting way better now i'm telling you! Im not yet sure of what to do if it shatters... lol...
Its definitly a weekend project, it just took a bit longer because i wasnt sure of how to do certain operations..
http://i111.photobucket.com/albums/n122/elninio123/Picture013-1.jpg
http://i111.photobucket.com/albums/n122/elninio123/Picture012-1.jpg
http://i111.photobucket.com/albums/n122/elninio123/Picture011-1.jpg
http://i111.photobucket.com/albums/n122/elninio123/Picture010-1.jpg
for the cutter i heated it until it was bright red and then put a few drops of motor oil until it lost it's color, then quenched it in a mix of water and motor oil. i guess i got lucky.. I probably wont be doing this again because I will probably end up buying a used indexible face cutter.. Cheers!
11-05-2006, 10:24 AM
That's very nice work Elninio. What alloy did you use?
Elninio
11-05-2006, 10:44 AM
probably 6061, thats what it looks like compared to other aluminum parts on my bike, when we went to pick up the aluminum, we just took generic pieces of scrap. costed about 6 bucks for a 1.25 x 1.5 x 3 inch block. Its a prototype, so it the alloy doesnt really matter at this time :D, just wanted to have a project to do on the mill. Still makeing changes in the design in order to make it easier to machine.
Your Old Dog
11-05-2006, 04:58 PM
Elnino, if you went into production on these why wouldn't they be cast? Seems to me that would be the way to go. Have them cast and then bore in the two holes and tape the threads.
One place that does small size orders that I know of is called Buffalo Metal Castings in Buffalo, New York. You might want to give them a call and see what 50 of these would cost you and what variance in tolerances they can produce that you can finish process at cheaper prices. Could end up saving you a bundle.
Also, why did you heat treat the HSS? I thought HSS bits were air hardening but I may be wrong, someone will know.
If your working with oil hardening steel there is a simple trick I learned from an engraver. Dip the cherry red steel that has soaked for the required time in a empty chicken noodle soup sized can filled with 10wt parafin base motor oil. Dip it right in the middle of the can and don't swirl it. Leave it in there about 3 minutes and the hot jacket of oil surrounding it will self anneal it in one process. It works great for me.
good luck, looks like fun project
ray........
topct
11-05-2006, 06:31 PM
"for the cutter i heated it until it was bright red and then put a few drops of motor oil until it lost it's color, then quenched it in a mix of water and motor oil. i guess i got lucky.."
Why are you doing this?
Dr. Rob
11-06-2006, 04:58 AM
I like it, 'Ninio.
It is about time somebody started shaving bulk and weight off those. I like yours; very clean. I really like the Odyssey one too though, the uuh whatthehellsitcalled, simple one-bolt one.
(Psst... tell ya something nobody else here knows: I still ride. I'm 37. Started riding in '83, and got a new bike six months ago after a twenty-year lapse. Lovin'it!)
Your Old Dog, no... casting is (usually) just not applicable for reasons of strength / fatigue and so on. C'mere for a minute; check this out:
http://www.metacafe.com/watch/258352/video/ ...just a hint of what 'Ninio wants to do.
Peter N
11-06-2006, 05:39 AM
Very nice work, well done.
Peter
Your Old Dog
11-06-2006, 05:47 AM
Un-freaking-real ! :D I can only imagine what kind of a adrenalin high that's got to be to be able to pull that off. I got drunk doing an occasional wheely on my motorcycle but this is waaaay over the top. Thanks for taking the time to post the link Dr. Rob.
Until my ankle mends this electric scooter is the best I can do for thrills ! But I have to say the other one (Bombardier 650 Max XT) will give you a cheap thrill too!
http://www.raymondswan.com/dp/eleccart%20(Small).jpg
sch
11-06-2006, 01:09 PM
If you are grinding your cutters out of HSS tool blanks, as it appears you are, there is no need or benefit from any heat treatment. They are optimally heat treated as supplied, Rc in the upper 60s, which they retain into the low red heat range, hence the name "high speed steel". Just grind and lightly polish them to the desired form and use.
john hobdeclipe
11-06-2006, 03:24 PM
elninio, check your private messages
Elninio
06-26-2008, 07:58 PM
here is the kind of abuse i've been putting it through, its still going strong.
http://lh3.ggpht.com/wrathofpyro619/SDyNYDsKBeI/AAAAAAAAAFY/8IgJ3n4T2CM/20080525_27.jpg?
also feel free to check out the other pictures of more stem abuse
http://picasaweb.google.co.uk/wrathofpyro619/SkateparkPhotos/photo#5205190713780340194
edit: the img tags aren't working - don't know why.
Chipslinger
06-26-2008, 08:09 PM
Like a Bad penny.....
A.K. Boomer
06-26-2008, 08:58 PM
Looks bombproof bro, "Lil" heavy but if i remember correctly you ride BMX? or something (so it should be built to the gills) As long as you tighten the stem mount first and then the handle bars it should be a great stem/bar mount, Nice work.
lane
06-26-2008, 09:36 PM
Now you can tell every one you have billet parts on your bike.
tattoomike68
06-26-2008, 10:00 PM
you have URL tags is why.
This thread is 18 months old too.
torker
06-26-2008, 11:21 PM
Chris...glad to see you're still pickin away with the bike parts.
Don't know if you heard.. Dustin "sorta" retired so he could get a real job before he got too old. I just heard he's going to a couple of shows this summer.
Russ
Elninio
06-27-2008, 01:08 AM
Russ
I haven't heard, I myself am trying to sell my bike, if I could only get 500$ on it ..
