View Full Version : Need bearing help
elcaminos
01-17-2007, 01:06 AM
A project I'm working on involves a 2.75"OD shaft with some rings/bushings that are a slip fit over the shaft but are 3"OD. I need to reduce the side friction of the bushings so they can twist freely. Is there any kind of a bearing that I could slip on between bushings like a washer that would allow them to roll around freely? I'm looking for something as thin as possible, around .125" or less.
sidegrinder
01-17-2007, 01:33 AM
If I'm reading you right, you're looking for some type of thrust bearing. You can go with needle caged rollers or probably much cheaper with some bronze/oilite types. Either one could easily be under 1/8" thick. Here's an example with only a 2"ID (they're not exactly giving these away, are they?)
http://www.amazon.com/Sintered-Bronze-Bearing-TT3001-03B-Thickness/dp/B000FMY9M8/sr=1-184/qid=1169011416/ref=sr_1_184/102-2987407-7930541?ie=UTF8&s=industrial
BTW, I checked out your project pics and I like the style of your machinists jacks. Have fun! Sidegrinder
Herm Williams
01-17-2007, 12:16 PM
Check with a auto transmission repair facility. the transmissions use a lot of thrust bearings mostli about 1/8 inch thick.
re
SGW
01-17-2007, 04:04 PM
Again, only 2" i.d. maximum, but you may be able to find larger elsewhere. See "Thrust Bearing" at www.mcmaster.com
pballdan
01-17-2007, 09:17 PM
McMaster also sells Bearing grade bronze sheets, you can cut your own out if you can't find what you need.
