I figured I'd put my version of Mr. Parkinson's cool little finger engine project project in a separate thread since I changed the construction up a bit.
The flywheel is made up from individual pieces since I didn't want to buy anything and wanted to do this project from stuff I had on hand. I used a cheapo 5C spindexer to drill the hub and the outer rim. The spokes are 1/4" drill rod. I put it together, then rolled a thin strip of brass and glued it on with super glue to hide the ends of the spokes. Crude but shouldn't fly apart at finger speeds.
The main body is made from round stock, again what I had on hand. I used some old inline skate bearings on the flywheel shaft and some nylon bushings on the other moving parts to reduce the friction. "Runs" good!
