Guys:
Has anyone had problems with an import tool holder fitting an aloris or phase II tool post? When I was at Cabin Fever I bought an import holder that was advertised to fit the aloris AXA tool post. When I got it home it would not fit. I adjusted the tool post to no avail. So I took the new import tool holder to the belt sander and after less than a minute of work in now fit my tool post. I do not think it is hardened as it seemed to sand quite quickly. Anyway the question. Has anyone else had a similar experience? If others have had the same problem then here is a quick fix.
Regards
Tin
Regards
Tin
