I'm sure this is an easy one. Just about easy enough for me to screw it up.
I need to make 35 pcs .125 x .375 x 3.400 with 4 holes 1" apart centered from end to end and side to side. Holes are .104-.114 dia. threaded 6-32 NC. Material is 4130 N. Starting with 1 pc .125 x 4.00 X 36.00.
Width and length tol +/- .010. The most important thing is centering holes.
Tools available- drillpress, 4x6 bandsaw, bench belt sander, T handled tap tool, micrometer and caliper.
My plan is to cut .375 wide pcs with saw, debur on sander, cut pcs to 3.400 lengths, clamp locating blocks to drill press plate and drill holes. Debur on sander, tap holes by hand. debur on sander.
My main concern is locating holes and correct dill bit and tap size.
Is this a good procedure? Advice on centering holes. Advice on drill and tap size.
I broker metal and mach/fab parts. I usually farm this kind of thing out. This one is small and looks easy so I'm going to do it in my basement.
Thanks
Thanks
