OK,
lets say you want to machine a rectangular plate that is 4" wide by 3" deep, thickness doesn't matter for this exercise.
There is a series of holes at differening centres that you have to drill by manual operation, using a DRO or CNC.
You start off with a drawing and lay the holes out then machine the part.
You have 5 possible points you could reference from, each corner and the centre.
State which one you would use looking in plan view, also assume the vise is positioned moveable jaw closest to you.
Not a trick question as there is no definitive right and wrong.
I'd just like to hear peoples views and the why.
