View Full Version : ATLAS TH42 Original Lathe Stand Dimensions
RockvilleRon
03-27-2007, 01:12 AM
I have an ATLAS TH42 lathe and after much searching I now have the originals metal legs. What were the dimension for a TH42 stand? I THINK the wood thickness was 1 5/8" Oak(??) top and bottome shelf and 10" wide(??), was the length 54" ??? I just want to be somewhere in the neighborhood of the original stand. So:
Two Oak shelves 54" long x 10" wide x 1 5/8 " thick????
Ami I close????
Thanks..Ron
kendall
03-27-2007, 02:19 AM
I've got a tv48 10" in the garage, I'll grab a measurement in the morning for you. Yours sound right though.
I was under the impression that the 'boards' were something a PO had thrown in though.
http://www.lathes.co.uk/atlas/page33.html
shows a 10 that looks like mine, but mine has a chip tray, and that one has what looks to be 1.5 inch boards.
ken.
IOWOLF
03-27-2007, 10:03 AM
It is 6 Quarter laminated maple on mine,and I have no reason to believe it is not from the factory that way.
JCHannum
03-27-2007, 10:24 AM
The 6/4 laminated maple matches the bench I have here also. The top for the 54" lathe is 57" long X 9-1/4" wide. The lower shelf is the same material but is 54-1/4" X 9-1/4". The stands were offered complete with the wood top and lower shelf as well as just the legs alone.
Atlas also offered a solid hardwood cabinet base that was patterned after laboratory benches. It appears quite attractive. I have never seen one of these.
Chipslinger
03-27-2007, 10:43 AM
My 10x24 is laminated something,could be maple.
kendall
03-27-2007, 06:40 PM
Sounds like you've got the measurements, mine are also 1.5 thick, 10 wide. Length on mine would be meaningless to you as mine's a shorter lathe though.
ken.
cmiller231
03-27-2007, 07:31 PM
I wonder why my th 42 has a metal chip pan with cast iron legs?????
Chris
JCHannum
03-27-2007, 09:15 PM
The metal chip pan was an option, available in two sizes for the various length beds. It could be added to any Atlas bench lathe.
RockvilleRon
03-28-2007, 12:40 AM
If I ever get it done I will post a photo or two......:-)
