View Full Version : Proxxon longneck angle grinder LW/E ?
Milacron of PM
04-11-2007, 02:27 PM
Got one of these today (new) and am quite un-impressed initially. Haven't actually used it yet but just test running the darn thing vibrates and just sounds bad...like a bad bearing or gear. But for all I know this is just how they are normally.
Anyone else here have one ?
CCWKen
04-11-2007, 04:04 PM
http://www.minicrafttools.com/proxxon/images/38544.gif
"The unit has a special, balanced motor with full-wave electronic speed control."
I'd say you have a lemon. Are you getting the vibration without a stone or disk mounted?
lazlo
04-11-2007, 04:09 PM
Don, where's it made? I know Proxxon is a German company, but...
aboard_epsilon
04-11-2007, 04:27 PM
I've got something from proxon apart on the bench ...says made in Taiwan on the motor.
all the best.mark
Milacron of PM
04-11-2007, 05:02 PM
Tool made in Luxemburg, accessories made in Japan and Italy.
It's much smoother without a wheel, but I tried all 3 wheels (flap type and solid disk) and same result. Kinda hard to achieve much without a wheel on it !
lazlo
04-11-2007, 05:17 PM
Is it possible the arbor nut is out of balance?
With Proxxon's reputation, I'd bet they have really good customer service...
CCWKen
04-12-2007, 12:00 AM
Ok, so you've established where the problem lies. Do we need to walk you through the solution?
Milacron of PM
04-12-2007, 08:18 AM
I have not yet established where the problem lies. I said it was much smoother without the wheel on it. It's still not "right" even without the wheel. If it ran "smooth as silk" without a wheel then it would be obvious the unbalanced wheels were the issue and I never would have posted in the first place.
I think the centrifugal force of a spinning wheel is just exagerrating a problem already present. Do I need to walk you thru how that is possible ?
