Hi all,
I recently made myself a D-bit type reamer. I have made a few in the past for use on non-metal stuff (mostly thin fiberglass and plastics) that worked out fine. I recently needed to make some fairly accurate and consistent 0.50" dia holes in some aluminum parts. So I made myself a 0.500" D reamer out of some W1 steel rod, ground nice, accurate angles on it, hardened and honed it. Looks pretty good. I tried it on a few test parts in aluminum. I drilled a hole leaving about 0.006" to ream out. I used the D reamer in the mill, very low speed, backed out frequently, well lubed. On three (these are holes that go all the way through the part) holes I got consistent 0.501" dia holes. That is close enough for what I am doing, and I can adjust the size of the reamer if need be, so I am happy with that part, but the finish was not so great. For what I am doing with this finish is not really critical, but in other cases it would be, and besides, it sort of bugs me.
I am assuming (dangerous, I know...) that this is a shortcoming in my technique. Hoping to tap the group wisdom here. What is the best way to apply one of these reamers? Any guidelines on speed, feed, etc. in aluminum?
Thanks for any ideas.
-AL A.
-AL A.
