View Full Version : Balancing a HF carbide grinder
heidad01
06-11-2007, 06:04 PM
I have had one of the famous! HF grinders for about a year now and it still has the original wheels. recently, when I turn the grinder off and the whells start slowing down, there is a loud grinding noise which goes away after the wheels have slowed down considerably. No Noise on the start up and while running. Do I need balancing? Where do I start? Thanks for all info. DavidH.
platypus2020
06-11-2007, 06:29 PM
I had a similar problem, with my HF grinder, found the mounting hub nut loose, retightened them, no more noise.
Jack
Mike W
06-11-2007, 11:58 PM
I had a slight noise on mine when turning it off. I pulled out the rotor and put it on the lathe between centers. I put one flange on with a nut and took a slight facing cut on it and trued the od. I then swapped end for end and did the same with the other flange. That did away with the noise.
