View Full Version : Question about EMCO Compact 5
rotate
07-02-2007, 01:12 AM
Few years back, I inheredted a brand new Emco Compact 5 from my father-in-law. I'm ashamed to say that it's only now that I'm dusting it off and trying to put it to good use.
I've tried mounting the both the vise and milling table to the carriage, but I'm finding that the spacing in the mounting bolt is different. Both the vice and milling table, which are Emco original, has 25mm spacing, while the carriage mounting holes are 17mm wide.
Anyone know why this is and how I can go about resolving this problem? Do I have to fabricate an adapter?
Thanks.
http://i7.photobucket.com/albums/y287/rotate85/emco1.jpg
http://i7.photobucket.com/albums/y287/rotate85/emco2.jpg
BTW, I'm very impressed by the quality of this machine. Everything is very smooth and tight.
plastikosmd
07-02-2007, 08:57 AM
lookin at your pics..the vice seems to be upright..in the correct position?? some sort of angle plate would be needed to connect the two...it probably doesnt mount flat as you are trying...just a guess..based on my south bend version.
Marcel Beaudry
07-02-2007, 09:11 AM
Dear Sir
to use your vise remove the set screw on the last hole
the vise uses one counterbored hole and the one that as the set screw
Marcel Beaudry
rotate
07-02-2007, 12:19 PM
Dear Sir
Marcel Beaudry
Thanks you sir. That did it! I did look at the set screw, but optically it looked smaller than the other. I think it was place there so that chips wouldn't fall in to the carriage during lathe operation.
http://i7.photobucket.com/albums/y287/rotate85/DSC00976.jpg
http://i7.photobucket.com/albums/y287/rotate85/DSC00975.jpg
Marcel Beaudry
07-02-2007, 12:22 PM
Do not forget to put it back so the chips do not get in
Marcel Beaudry
dp
07-02-2007, 01:01 PM
In this configuration that set screw might be intended to go in the exposed hole for the same reason it's put in the original hole.
plastikosmd
07-02-2007, 05:56 PM
well there...lot different than my SBL...bout 90 degrees off, learn somethin every day
scott
Joel
07-02-2007, 06:06 PM
Scott, Rotate's Emco has a milling head, like a 3-in-1.
plastikosmd
07-02-2007, 06:56 PM
oooooooo
thank you..that helps..grin...
scott
