View Full Version : Compound Rest Setting.
07-05-2007, 03:57 AM
When cutting a RH thread away from the chuck,(threading tool mounted
upside down, lathe in reverse) should the 29 degree compound rest angle be
set towards the tailstock or the chuck .
I recently, successfully cut a RH 5/8 unc thread in this way,with the compound set 29 degrees towards the chuck.
07-05-2007, 04:35 AM
You always feed it into the direction of cut. So you set your compound so it advances into the direction the saddle will move.
