View Full Version : Bearing fit
timh
07-16-2007, 09:58 AM
If you make a spindle/axle for a bearing how tight should the fit be? Slide on our press fit? Say a 5/8 dia.
JCD
07-16-2007, 10:56 AM
About .0001" to .0004" interference, depending on bearing design, journal surface finish, load, speed, lube, service factor.
Swarf&Sparks
07-16-2007, 11:06 AM
what kind of bearing?
07-16-2007, 11:50 AM
As well as expected service temperature range and the phase of the moon when installed.
Swarf&Sparks
07-16-2007, 11:52 AM
Moon phase is only relevant to phos bronze!
timh
07-16-2007, 12:30 PM
This would be for a wheel bearing light duty use.
Swarf&Sparks
07-16-2007, 12:38 PM
"wheel bearing light duty use"
sorry Tim, you're gonna have to a lot more explicit if you want a meaningful answer.
"light duty" for a garden wheelbarrow or
"light duty" for an occasional run at Bonneville on a 1920 Indian Scout?
Pardon me if I sound facetious, I've heard sillier questions asked by engineers.
tattoomike68
07-16-2007, 01:22 PM
It its on a haul wagon that you pull behind a tractor then .001 clearance slide fit is fine. you wont need a hammer and chisle to change the bearing if it ever needs it.
It may be a bit tighter if its on a boat trailer that goes down the road at 65 MPH.
Rich Carlstedt
07-16-2007, 10:50 PM
If the spindle is stationary, as in an automobile front wheel bearing, The spindle should be loose sliding fit, and the OD should be a press fit.
If the spindle turns, then it is opposite, with the spindle being a press fit, and the OD a sliding fit.
Rich
"Loose" is .0005 clearance
"Press" is .0003 interferance
John Garner
07-17-2007, 02:37 PM
The bearing race that rotates relative to the load should be tightly fitted, the bearing race that is stationary relative to the load should be slip-fitted.
Swarf&Sparks
07-18-2007, 09:14 AM
I'll happily do a 0.001" interference fit on an ali bearing block (outer race), just press it in with the bench vice.
I wouldn't like to try that on steel or cast iron though.
Colchester John
07-18-2007, 06:06 PM
The simple old rule was "a thou interferance per inch of diameter". i.e. 1/2" = 0.0005", 1" = 0.001" etc.
This has always worked well for me...!
Ken_Shea
07-18-2007, 11:27 PM
While the "Expert" engineers will spout the fact that bearings all have a specific fit per use, I have to grin, because I know from experience that in reality, more often than not, all those extremely precise specs get amazingly forgotten while in the manufacturing mode.
Except for the bearings themselves.
