I want to make a non-conductible prototype that will eventually be made of injected plastic. Making and modifying the injection mold is the hard way to do it, so I want an epoxy prototype that can be altered easily if I want to change design details. It would just require mixing up some more 2 part epoxy and filling the holes, then re-machining.
Is 2 part epoxy easily machinable? Use low speed or high speed? Is it tough on cutting tools?
