View Full Version : DIY Solar Shop Heat Ideas?
hitnmiss
08-14-2007, 03:27 PM
Any experience/thoughts on DIY solar heat ideas?
My shop is one car of a 3 car garage. It's pretty well insulated. Normal winter heat is a 110V electric radiant oil heater set to maintain 50-55 degrees. I'd say in really cold weather it's probably on 1/3 of the time.
When I use the shop I put out a 2nd 110 infrared heater to radiantly heat me quickly and eventually the whole shop if I'm out there long enough. I'm in Colorado so a fairly mild climate all things considered.
I'm toying with a home made solar panel and a radiator in the shop to supplement the always on 50-55 degree heater. I don't expect to actually heat the shop but if simple enough I figure why not??? Maybe a small electric solar panel to run a small water pump and a small electric fan in the shop exchanger.
One problem I have is convenants. No solar panels allowed so I have to stay stealth and or might have to throw away if the neighbors gripe. I'm thinking a single 4x8 panel on the ground below the fence might stay under the convenant nazi's radar. But would that be at all effective? Back of my house faces south-south west.
Worth playing with or total waste of time? (which I do a lot of)
BadDog
08-14-2007, 03:43 PM
Move to Phoenix. I have VERY effective solar heat in my shop, and didn't cost me a dime... ;)
topct
08-14-2007, 03:44 PM
I'm guessing about 300 square feet.
A single 220 volt 3500 watt heater would be really simple.
JoeFin
08-14-2007, 03:54 PM
Would be funny to paint the inside of your rain gutters black and soldier 1/8" copper soft tube on the bottom of it
Rich Carlstedt
08-14-2007, 04:01 PM
Not at all.
Solar can be very effective, particularly if you have Southern View access, as you have.
How about a passive solar panel with Thermo syphon feed ( no pumps.)
Build a box with foam insulation and plexiglas window. Better yet, find a picture window (double glazed) that is being tossed.
Make the box 6 inches deep and place some copper pipe in a serpentine
method, starting at the bottom and going up.
Lay the box at an angle against the wall facing South.
The hot pipe goes out the top and through the wall and then continues upward till it reaches a old car radiator mounted near the shop ceiling.
The hot pipe should dump into the TOP of the radiator. The bottom of the radiator should go downward /then outside and into the bottom of the box.
As your fluid heats up, and if the lines go vertical, the warm fluid will naturally travel to the radiator. Place a small fan behind the radiator and warm air will be blown around the shop. When the Sun no longer shines, the flow stops automatically, and no heat is lost from inside to outside.
The fan can be any simple fan. Use antifreeze for fluid. Be sure to extend the top of the radiator with a open top bucket so you have a expansion reservoir.
The pipe should be at least 1/2 in size, and the inside of the box painted black
You will get temps of upto 180 in the winter and 220 in the summer.
Cover it with a white tarp.
I did mine just below a window years ago, and made a baffle for the open window (cracked open 2 inches) and the pipes went throught the window baffle, so I didn't have to drill holes in the wall.
I bought the copper pipe/tube at the junk yard for scrap price.
I knew a giuy who did the same thing almost, but instead he went with Air heat.
His box was nested beer cans with no lid and sprayed Black.
he blew air behind the cans and then into the garage. but he needed fan housings and temperature controls ,
Rich
IOWOLF
08-14-2007, 05:06 PM
http://img.photobucket.com/albums/v11/iowolf/SANY0095.jpg
I have had this one on my shop since 02, I can get 120* heat out of it on a good sunny day,in February, when it is 20* outside.
hitnmiss
08-14-2007, 06:19 PM
great replys, thanks.
IO, is that a water heater or direct air panel?
hitnmiss
08-14-2007, 06:25 PM
I like the idea... Need a good way to hide it from the neighbors for sure.
The standby heat electric radiator is on low and might be on 1/2 the time when very cold... "low" is 750 watts so if I could get even 200 watts into the shop for 3-4hours a day I think the effort would be worth it.
BTW, my electric bill doubles in the winter because of the shop but it's still darn cheap, maybe $30 bucks a month for 4 of the worst months.
The acual cost isn't a bigge but I'm cheap so I wind up leaving the heat a little lower than comfortable.
IOWOLF
08-14-2007, 07:40 PM
Air only, there were 2 but other was busted after a tree fell on it,I got it for free,The price was right.;)
speedsport
08-14-2007, 07:57 PM
looks good Wolfie, would be nice if you could hang a light bulb on the end of that hoist so you could see at night, maybe a 3 phase one.
speedy
08-14-2007, 08:44 PM
I just blew snot across the desk :) :) :) :) .I love humour; that has brightened my day.
JoeFin
08-14-2007, 09:05 PM
I'm planning on extending out the back wall of my shop and will definitely be adding solar heat in the concrete slab.
During the summer months it will be piped out to the pool and hot tub. A couple of relays and solenoids and the process would be effortless to maintain
wbleeker
08-15-2007, 02:42 AM
There is a black polythene pipe used for drip line irrigation etc, I am not sure if it is called Low or High density, someone will know, But it is cheap and you can get push in fittings for it. Our swimming pool at home has solar heating with a black rubber mat system on the roof, a timer and a pump to circulate the water.
Will
rgbai
08-15-2007, 05:11 AM
http://www.mobilehomerepair.com/article17solar.htm
Rex
08-15-2007, 09:34 AM
http://www.builditsolar.com/
08-15-2007, 10:23 AM
I'm still trying to figure out why you have a covenant that prohibits solar panels. It's not like they make a lot of noise or spoil the view or something. It certainly isn't very 'green'. I would suggest that the covenant should be abrogated, at least that part. It should be possible to make the people responsible for the covenant feel like tratiors to the US, mom and apple pie, not to mention the environment.
hitnmiss
08-15-2007, 11:19 AM
I agree, I think as energy prices soar the covenants will be forced to change. Solar panels aren't beutiful but they are a heck of a lot prettier than Marines dieing in the middle east to insure cheap oil.
jkilroy
08-15-2007, 11:53 AM
Can't have solar panels in Colorado? That blows the mind given the general left wing stance that most of the state takes.
08-15-2007, 01:05 PM
Hmm. That sort of covenant is what is called a "restrictive real covenant" aka a negative covenant. If you breach it the only remedy available to the originator of the covenant is to obtain an injunction to cease and desist from the activity in question. That costs money and they can't recover it from you. In particular there is a general principle regarding restrictive real covenants that applies in all jurisdictions when such a covenant applies to more than one land owner. It must be shown that the breach of covenant somehow is to the detriment of the interests of the various and several parties to the covenant, not just to the one who enforces the covenant. [edit] In other words, it must be shown that it has a negative effect on the other people that are also restricted by the covenant. That can't just be based on "I don't like it".
I suspect that would be hard to do today in respect of a green energy source. At the most you would be liable to remove the offending structure. So, build it so that it is easily moved. How about attaching it high on a side wall? I bet the covenant says "roof".
Note: I had issues once with a land covenant on the last place I lived. It turned out to be unenforceable.
IOWOLF
08-15-2007, 02:22 PM
OK lets play Hangman...
3-Phase-LIGHTB_LB, all thats missing is "U". :)
speedsport
08-15-2007, 10:24 PM
some people don't like to play when they don't control the "BANNED" button', wussies!
IOWOLF
08-16-2007, 06:30 AM
Oh How True it is. BTW I have been on the site and am a current member from a different Place ,But I never post.
