View Full Version : Sheet Metal Brake
kruszert
08-20-2007, 09:49 PM
I need to purchase a sheet metal box brake to do some light 28 ga. galv.
sheet metal ductwork and also some 20 ga. aluminum. I am looking at the Enco brake on sale for $430 - - it is 48" wide and rated for 16 ga. mild steel.
But, I also have to bend some 16 ga. stainless steel 36" wide. Any chance this brake will do the stainless? I have looked at past posts and I think the answer is - - no way - - but the price sure is tempting and I only have to make a few bends in the stainless at that width. Does anybody have one of these or similar model and have any comments? Would it bend 16 ga. stainless 24" wide? I may be able to get away with that width.
Thanks,
Reggie
AZSORT
08-20-2007, 10:23 PM
I've had one of those for several years, and have used it mainly for 18ga cold rolled with good success. Your 18ga SS will test its limits especially if you want a tight corner radius. I've taken some steps to beef up mine like replacing the bolts with hardened ones and welding solid some of the joints. I'd still like to find a 4 to 6' hyd. press brake I could afford.
Greg
PTSideshow
08-20-2007, 10:31 PM
the brake will work for everything but the SS18ga if you only have a couple of simple bends on the SS get the brake and then take the SS to a sheet metal shop[ for the bends and your done and still have the brake:D
They are the far east style manufacture, I have a DI-arco box and another brand seamer and they mean what they say about the ga. As thicker you will need to hold it closed and bend the brake at least 4 arms are needed.
kruszert
08-21-2007, 02:48 PM
Thanks for the replies. I figured the stainless was most likely not going to work. I have been looking for a larger used one but there aren't many and when I find one it is way too expensive.
Reggie
IOWOLF
08-21-2007, 05:58 PM
Where you from?, I know where there is one.
kruszert
08-22-2007, 09:27 AM
I am in Richmond, Va. --- I looked at your profile and it said West Iowa so it would have to be a looooong way from there for me to go get it. The brakes that are rated for 12 ga, which is what I need/want, are usually like 800# or more. No problem for my trailer but shipping cost adds up.
Thanks for the thought,
Reggie
GKman
08-22-2007, 10:53 AM
IOWOLF,
I'll bite, I'm in NW Missouri (Saint Joseph).
Scishopguy
08-22-2007, 02:55 PM
Krusert,
I just got my latest Harbor Fart flier in the mail and they have just what you need for $179.
Item:
36" metal brake with stand
Lot #91012
12 ga. mild steel
I have looked at similar brakes in the local HF store and they seem to be reasonable quality construction. It isn't American iron but will probably do the job. ;)
neonman
08-22-2007, 04:30 PM
I've been looking at that 12ga break too, and have found the same one by another supplier. They say 12ga narrow widths...
neonman
Mcgyver
08-22-2007, 05:06 PM
Lot #91012
12 ga. mild steel
you get what you pay for. manual says 18" wide in sheet metal, 22 gage in mild steel. wonder what sheet metal they're taking about @ 12 gage, lead? :D
IOWOLF
08-22-2007, 06:55 PM
I will get pics.and specs if you want them, but it is a press brake.
