View Full Version : Jig for Cuttermaster - more pictures
tiptop
09-01-2007, 12:21 AM
Here are a couple of shots, almost done with phase 1. Phase 2, will be adding the cross slide with a bearing under it, in place of the current tool holder, to knash end mills and sharpen the radius'. Phase 3, is to make riser blocks for the motor, so I can get under the wheel to sharpen horizontal type cutters. Phase 4 will be to make a couple of centers set up on another plate, so I can grind between centers and swivel the jig for tapers. I am going to be at this project for a while with these expectations.
http://i155.photobucket.com/albums/s290/jaytiptop/CuttermasterJig-B004.jpg
http://i155.photobucket.com/albums/s290/jaytiptop/CuttermasterJig-B005.jpg
jkilroy
09-01-2007, 01:19 PM
Thats fine work, can you share some details about which parts you made, what you scrounged, etc?
tiptop
09-01-2007, 11:36 PM
Please see the other cuttermaster post, I combined the two, as I should have in the first place. Thanks for looking and the comments. Jay
