View Full Version : rose engine
aostling
09-10-2007, 08:07 PM
Has anybody tried guilloché turning? It's done on a rose engine, a type of lathe which hasn't been made commercially for years.
From the videos shown here http://www.rgmwatches.com/engine.html it appears that rose engine lathes turn at about 0.2 RPM. If you want to make such a lathe, http://home.vicnet.net.au/~pwguild/o-rosego.htm tells you how.
[edit] I should have searched the Archives. http://bbs.homeshopmachinist.net/showthread.php?t=24226 is one of several threads on this topic.
Mark Hockett
09-11-2007, 12:13 AM
Allan,
Here is a link to the Ornamental Turners International web site, you might find some more info there.
http://www.ornamentalturners.org/.
aostling
09-11-2007, 12:39 AM
Allan,
Mark,
That's an inspirational video, gives me ideas about what can be done with my hunks of hard mesquite.
Norman Atkinson
09-11-2007, 02:26 AM
Allan,
I have always wanted to go this way but there is only one lifetime.
However, there are quite a number of books on Ornamental Turning. I think the classic is by Holzappfell and although old- very- has gone to several reprints. I have the four volumes but I suspect that there is another one.
Again, 'Tom Walshaw writing as Tubal Cain did one more recently and used his Myford lathe as well as more fancy stuff.
Rambling on, I recall several articles from the Society of Ornamental Turners in the UK and CNC is quite possible. It was written up in MEW some time back.
Earlier, again in MEW, was how to make an elliptical chuck. Sounds tasty?
So you can now start on making your Eiffell Tower on the lathe- or not.
Good luck
Norm
IOWOLF
09-11-2007, 05:02 AM
Yep them archives are there for a reason.:)
laddy
09-11-2007, 07:16 AM
Fascinating. Looks like a great project.
A.K. Boomer
09-11-2007, 08:01 AM
] it appears that rose engine lathes turn at about 0.2 RPM. .
That would fit right in with all the other things I like to do like watching paint dry, grass grow And gw do something positive for the world...:p
BadDog
09-11-2007, 02:27 PM
Hey Alan, one of our local guys right here in the Valley is into Rose Engines and has several. I even got to run it for a bit. They are much faster than 0.2 rpm, but not fast like a regular lathe. They also generally use a powered head that does most of the cutting work, so unlike normal turning, it doesn't take hundreds and thousands of rotations to accomplish something. It actually goes rather fast.
