View Full Version : compact5 belt
guynamedbathgate
09-12-2007, 11:34 AM
hey everyone. trying out this forum after being yelled at over at the practical machinist forum for being a "HOBBYIST".
I just aquired a little Emco compact5 converted cnc lathe. its in the mail but it does not have a drive belt.
anyone know what the size (length width) of the belt on these things is so i can buy a suitable replacement before it comes? the seller didnt know.
pretty sure the drive pulleys havnt been modified so it would be what ever size was standard on these lathes.
lynnl
09-12-2007, 11:37 AM
Sorry, can't help with your question, but anyway - Welcome to this group.
Lynn
jesse557
09-12-2007, 11:42 AM
Welcome,
This is probably what you are looking for:
http://www.unimat.homestead.com/
guynamedbathgate
09-12-2007, 11:45 AM
hmm not so sure. its definately not a unimat. more akin to a mini lathe than that. but still not so sure it will be the same as Harbor frieght or grizzly since it is form the early eighies and built a good deal better too.
Having a hard time digging up info on it for some reason
emartt1
09-12-2007, 03:06 PM
Take a look at www.blueridgemachinery.com They list the following parts:
ZRM406335 Vee belt 6 mm small drive belt 19.50
ZRM406450 Vee belt 6 mm large drive belt 25.00
guynamedbathgate
09-12-2007, 04:26 PM
yeah i saw that. price seems a bit steep if you ask me. thats why I was curious if anyone new the dimensions of the belt. Im sure I can find cheaper than that from a belt supplier.
Alistair Hosie
09-12-2007, 04:46 PM
I like hobbiest many of us here are hobbiests so feel at home also those who are not hobbiests have a lot to learn from us who are:D:Dand if you have anything you don't know ask me and I'll have a word with his lordship:D:DAlistair
pcarpenter
09-12-2007, 05:02 PM
I think the department downstairs still has a Compact 5. I will run down and see whether I can get a measurement (provided it has a belt):D
Edit-- I just went down and the guy in charge of that shop is not around today. I pulled the side cover and determined that I would have to wrench on his machine to loosen things enough to get the belt off so I am going to forego that for today. I did find, however, that there is a motor pulley, an idler pulley and a gearbox pulley. There are a couple of steps on each of the first two, giving you several speeds with various belt combinations. So, unless you know which belt is toast, you won't know what to order until you get it anyway.
Paul
guynamedbathgate
09-12-2007, 05:49 PM
Im starting to think I need both. belts. hmm well if you can get both measurments Id sure apreciate it.
Chris
bob_s
09-12-2007, 06:12 PM
Chris:
Check out 8x18Lathe group over on Yahoo. Full details on the EMCO C8.
IOWOLF
09-12-2007, 07:40 PM
O-ring in a pinch,like on a unimat.
It worked on a C-5 cnc for me.
Your Old Dog
09-12-2007, 08:48 PM
Hey guys, look! Another "HOBBYIST".
:D Welcome to the board! Hope you enjoy your stay and hope you have a goodtime when the UPS guy finally gets there !!
sch
09-12-2007, 11:05 PM
The small belt on my C5 is 6x335 for the idler pulley
and the larger belt is a bit smudged in the printing
but most resembles 6x450.. It could be 6x460. There
is enough play in the motor mount that either would
work. Both are V belts, toothed, with a 6mm width
across the base of the V. Not obvious how the small
belt is removed as there is not much slack in the
system. Interpolating the 335 implies 33.5cm length.
The 450 measures about that, (45cm).
Brief search at McMaster shows the closest to be 2L13
and 2L18, but not apparently available in toothed versions
there. ($4.07 ea). MSC has toothed 2L but not shorter
than 2L18 size. ?Motion Industries.
Too_Many_Tools
09-13-2007, 02:54 AM
LOL...seems to a lot of that going around these days.
Don't sweat it....any of us who have had business dealings with Thomas know that he is difficult to deal with.
I would say it is PM's loss and HSM's gain...kick your shoes off and stay for awhile with the rest of the "hobbyists".
And personally I would take being called a "hobbyist" a compliment...just take a peek at what the so called "professionals" over at PM are discussing now...
http://www.practicalmachinist.com/ubb/ultimatebb.php/topic/30/7331.html
Topic: OT...Way OT... Dating barmaids...
How seriously involved with your local pubs barmaid do you have to be before you stop tipping her?
I draw the line at "living together" but my buddy says once you've bumped uglies four times...
Are there any books on the subject???
LOL...yeah right...really professional. If they ask me, I would say it depends on whether she owns a Bridgeport or not. ;<)
In regards to your Emco belt question, others are giving you other good sites to check for the belt....the 8x18Lathe group over on Yahoo is a great one.
In response to your question on PM about the Sherline cnc rotary table
(which was a very good question...shame on you Thomas), I would check the Yahoo group
http://groups.yahoo.com/group/SherlineCNC/
and the site
http://www.cnczone.com/
You will find helpful folks for both the software and hardware needed to make it happen.
In regards to the Emco Compact5 lathe, you are going to love it.
And be sure to show us how your final project turns out....us "hobbyists" here at HSM are actually interested in machining and not just in dating barmaids like the "professionals" at PM are. ;<)
TMT
IOWOLF
09-13-2007, 07:20 AM
Once you bumped Uglies the tipping should stop.
When you live together She should tip you. :)
guynamedbathgate
09-13-2007, 08:23 AM
ok I checked with the seller. he said I only nee the large belt. so Pcaprenter if you can get permission to measure. I guess I only need the measurement off the longer of the two belts.
Thanks
Chris
guynamedbathgate
09-13-2007, 08:36 AM
woops sorry didnt realize there was a second page to the post. Hey thanks for the info. yeah Ive noticed over there on PM that the answer to most questions is "buy a Bridgeport" or "your machine is too small". lot of chest thumping over there. I also got a lecture on using a flood cooling system on my cnc mill because I didnt use it often enough to justify flood coolant.(with the rusting problems it causes)
as for the compact5 . I think it will be just the thing. I have a 14x40 lathe and 9x20. but I was looking for a little cnc to make all the little tedious repetitive round things I have to make from time to time for my art
thanks again.
Chris
guynamedbathgate
09-13-2007, 08:51 AM
found a 457mm notched belt at Stock Drive Products
http://sdp-si.com/
I guess thats imbetween the two sizr possibilies above so Im gonna go with that one. Ill make it work one way or the other I guess.
chris
