BadDog
09-20-2007, 03:46 AM
As stated on another post, the tachometer (manometer) in my new drill press has a broken tube. Right at the bottom, below the sight window, so repair is pretty flexible with respect to appearance. But the oil that goes in it is very expensive if I get the right stuff (about $25 a pint; not break the bank, but give me a break...), or some folks just use Dexron III which is VERY close, but will read a few % lower than the recommended stuff. Plus, if it leaks out, no big deal but the mess...
So, you can no longer order the part (I'm told). <shrug> Not that I would given typical pricing. I can order tube from McMaster, but it has to be tapped with a funky 3/8" fine thread for the feeder. That or make up something else, which is no biggy. Or, maybe I can fix the broken tube sufficiently for my needs? This is what I want to investigate (hopefully with your help).
It has a (roughly) 3/8 ID (measured) and between 7/16 - 1/2 ID (need to measure). It is a straight hard plastic tube, that appears to have been heated and bent almost 90*. It broke in the bend. I'm thinking there are several ways to go.
1) Machine a simple aluminum(?) block to provide a 90* elbow. Easy fit for the tube. Maybe an o-ring groove inside both holes. A countersink on the outer edge. And fill that countersink with common RTV gasket maker. Probably don't even need the o-ring. Tube would just need a little trimming to remove the are distorted by the heat/bend. But the threaded part and all the rest would still be perfectly useful with no additional fuss.
2) Use heavy heat shrink tubing to hold the pieces together and reseal them. Particularly the type with adhesive (or RTV?) inside. But I'm not sure how it will hold up to the fluid. But there is no pressure or stress on this piece, so as long as solvent didn't cause a problem, it should work fine, I think.
Other ideas? If it doesn't work, I'll just go the McMaster route and order some hard tube. I've also got flexible tube I use for fuel cell sight gages, and that could be made work with a supporting back plate. But it's got a yellowish tent, so not totally ideal...
