View Full Version : shaper question
Alistair Hosie
10-18-2007, 11:45 AM
I noticed when I opurchased my shaper someone before I had it bent the power traverse lever into a slight curvature. I have since noticed on many others the same thing has been done there is obviously an advantage in this but what is it ??? I can only think, it helps smooth out the motion to have a slight curve in this.I suppose it seems to make sense .I have left mine as such and not disturbed it anyone else thought,or noticed this???? Alistair
dp
10-18-2007, 01:29 PM
If you have multiple ratchet wheels it allows you to better take advantage of them by reducing or increasing the angular motion of the pawl.
10-18-2007, 03:43 PM
Actually, if you extend it too far without hand pulling it through a rotation they are self bending.
dp
10-18-2007, 04:25 PM
Or worse :)
Speaking of feed stuff, how many teeth are on your replacement ratchet wheel, and what did you end up with for a cross-feed rate?
