View Full Version : OT: Solidworks ORB Fittings
Shuswap Pat
10-21-2007, 09:10 AM
I am trying to draw a hydraulic fitting in Solidworks, and put in a -12 O-ring Boss Port. It requiers a 1 1/16-12 UN thread, which I don't have in my 'Hole Wizard'. Any sugestions on how to 'build' the thread, or where to find the port already drawn?
Thanks
Tony
10-21-2007, 09:25 AM
Have you had a look at/through 3D Content Central ?
Must register, but there are large libraries of 3D downloadable
parts/assemblies.
Check the hydraulic fittings section, or find a suitable part you can
harvest the feature from.
-Tony
motomoron
10-23-2007, 03:35 PM
Many manufacturers offer product drawings in .SLDPRT as well as the customary .DXF and .DWG format. When I need to model anything that already exists in the world as a manufactured entity, I start with a search for a downloadable file. I'm sure all common hydraulic and AN fittings are readily available.
nheng
10-23-2007, 07:15 PM
I don't know if SolidWorks has something similar but SolidEdge has a hole table file which can be altered by the user.
