I need to get a bit to use on a flycutter for facing off 2024 aluminum. I have an R8 shanked flycutter that takes a 5/16" inch bit. Can you buy these specific for the job or do you need to grind these yourself. I've never used a flycutter before. Any specific brand that you've had good luck with?
What kind of material ....HSS / Carbide...coated or uncoated?? and any suggestions on RPM's to run these at. 2" square aluminum blocks will be used.
Thanks in advance.............Krems
