View Full Version : Where to buy D1-4 pins?
cybor462
10-24-2007, 11:41 PM
I just bought a dog plate on ebay (not a face plate) a dog drive plate. It is for D1-4 but does not have the pins. They are threaded 7/16 20. I have looked on several sites like Enco , MSC, Shars. So far no one has them listed.
Any idea's?
BadDog
10-24-2007, 11:56 PM
PM me an address and dimension info. I think I may have a set for you from a Clausing face plate. It was labeled D1-4, but I don't remember the threads...
cybor462
10-25-2007, 01:01 AM
Bad..tried to PM but your box is full.
Here is a link to the specs for a D1-4 pin remember mine has a 7/16 20 thread.
https://www.victornet.com/cgi-bin/victor/reference/Lathe_Chuck.html
Is it this hard to find pins? May be why this was for sale on ebay.
BadDog
10-25-2007, 01:21 AM
I cleaned out some PMs. They don't give you much here do they? Anyway, I'll try to dig them out tomorrow and get some basic info. Legs are killing me, so I'm done for the night, except for waiting on them to settle down.
cybor462
10-25-2007, 01:24 AM
Thanks for your help. Go rest or better yet go to bed. I need to be up by 6am and I should be in bed too.
Thanks again. I did send you a reply in PMThanks Again
Jim
Malc-Y
10-25-2007, 06:46 AM
J & L Industrial Supply in the UK list Camlock studs made by Bison in their current catalogue, but they are listed with metric threads.
CKB-99104L
M10x1 CAMLOCK STUD / S/C/CHUCK D1-4
Manufacturer: Bison
Manufacturer Part Number: CKB99104L
Availability:0 in Stock
Your Price: 11.02 EA
Other sizes are also listed.
Malc. :cool:
Mcgyver
10-25-2007, 09:12 AM
last i looked (eons ago) the only place i could locally find them was Kar or one of the crazy expensive European tooling places, they wanted like $40 a pin so i made them. not hard to do. I used drill rod and left it annealed and its worked perfectly.
ammcoman2
10-25-2007, 09:13 AM
KBC lists them as well (Bison) but with metric threads only. # 7-899-104. It states that the thread is M10x1 so they are a bit too small for your catch plate. Perhaps an insert could be made.
Geoff
Malc-Y
10-25-2007, 09:39 AM
You could always just drill and tap three new holes on a 3 1/4" p.c.d. for M10 x 1mm and fit new metric studs.
Malc.:cool:
rkepler
10-25-2007, 09:45 AM
JLIndustrial has both metric thread and UNF - see their part number MCT-55708C Not a bad deal at $14.35, I couldn't make one for that. They list the MSC part number where it's listed at $13.80
cybor462
10-25-2007, 10:12 AM
I must be stupid I looked for hours online MSC and did not find a thing.
I will go check J+L and see. The ones I have now are hardened and ground. I use my lathe heavily and am changing chucks 4-5 times daily at times. If the pins are not hard they will wear quickly in my application. Making them was not an option for me.
Thanks guys for all your help.
Herm Williams
10-25-2007, 11:55 AM
I made two sets, used drill rod. Turned the rod down for the threads cut the threads, used horiz mill to cut the camlock grove in the side of the pin,then used the verticle head of the mill to cut the lock screw grove in the side. If you have a horizontal mill with a verticle head the pins are easy to make.
re
cybor462
10-25-2007, 03:53 PM
Thanks for the help from you guys here I found (3) places that have them. They were not advertised in 2 MSC, Enco only J+L. Since they are all the same company I tried to get Enco to get them. Well it seems that MSC has 1 and J+L has 1 and Enco 0. I need 3. Bison has them for 39.00 each so I elected not to go that route.
At this point my choice is to have MSC order them special order and drop ship them. Will be expensive.
Can't understand why it is so hard to get these. The metrics are all over. USA thread no where. Makes you go Hmmmmm!!!:mad:
