View Full Version : Surface finish problems
timh
10-25-2007, 05:13 PM
Hi i am having problems with turning steel on the lathe the surface of the steel looks like very fine threads. I am turning 1in. cold roll and have tryed hss and carbide with the same results any ideas? Also speed seems to make no difference.
tattoomike68
10-25-2007, 05:18 PM
Cold roll 1018 is not known to be easy to get a good finnish on. I use a file and emory cloth to smooth it from an oversized state.
1140 stressproof is a dream to machine.
toastydeath
10-25-2007, 05:23 PM
Try a small (1mm) radius tool, so it wipes away the tool marks at low feeds.
If you are using inserts, you should be able to buy an uncoated carbide insert with that kind of nose on it.
SGW
10-25-2007, 05:39 PM
Minor nit, I think Stressproof is 1144, but yeah, in my experience it turns to a beautiful finish. Generic "mild steel" cold-rolled can be a colossal pain.
Grind up a HSS tool and stone the edges after grinding to get rid of the grinder marks...or use a fine grinding wheel. Stone a small radius on the tip, and see how that works.
timh
10-25-2007, 05:59 PM
Thanks for the tips i will try them out and see what happens. Can you weld 1140/44 stressproof and how does it wear?
Joel
10-25-2007, 06:06 PM
How much feed are you using and exactly what speeds?
dalee100
10-25-2007, 06:39 PM
Hi,
Personally, I think welding stress proof pretty much sucks. Being a "tool steel" it will harden and crystallize causing it to become brittle. It does have excellent wear characteristics though and machines pretty well. I go through a lot of it at work.
And yep, 1018 is hard to get a good finish on. If you need a high finish on 1018, I would suggest using a different finish method, (like tattomike68 suggested), or switch to a material that can give the desired finish without a second operation.
dalee
BadDog
10-25-2007, 06:41 PM
Agreed, I hate turning "mild steel". It tends to want to get "fuzzy" due to tearing, and it's hard to get a good finish regardless of what you do.
I've had the best luck with negative rake tooling (and typically a minimum 0.030+ DOC), but that's on a Mori Seki I sometimes use. My home lathe won't run negative.
So I find I do best with a specially ground HSS tool. I use a regular roughing tool and screw the finish till I'm getting close, then switch to the "special" tool. It has a rather significant (deep and narrow) chip breaker with a sharp curve and providing a fairly high positive rake edge. The point has a small radius, at least a bit wider than the max feed rate I'll run it at, and all hand stoned with a diamond lap before use.
BUT, here is the key (I think). You have to reduce the clearance relief to near nothing. This is only a finishing tool and will not take more than ~0.010 to maybe 0.020 MAX DOC cuts. I often run it at less than 0.010, and it also serves as my "skim a thou or two" tool. Feed is not so sensitive, but generally slow since I'm looking for finish. The reason for the minimal relief is that it will want to suck into the material due to the high positive rake. Pretty much any positive rake tool (the most used by HSMs on light lathes) will want to suck in on the mild steel, and this is what (seems to me) causes the tearing. The small relief prevents that AND provides a sort of burnishing effect.
I've actually gotten some rather decent (enough to use as machined) most of the time. But sometimes I still have to go to the file and emery routine. Also, in this case, you don't want your typical lathe bastard to do the finish cut. It'll leave almost as a bad a finish. IMO, you want (and I use) a finer toothed single cut mill bastard and a modertely light touch, perhaps with either WD40 or other light oil. Optionally, I use chalk a lot. This will remove the fuzzies and leave a decent finish. Finally polish with emery if desired.
I do a LOT of "mild", and this is what I've come to believe is the best way given what little I know and the smallish antiques I have to work with...
timh
10-25-2007, 06:48 PM
Thanks bad dog and everyone else i do need to be able to weld the part so i will just play around first and see if i can get a good finish.
BadDog
10-25-2007, 06:58 PM
Oh, and on the finishing tool, you'll generally want to use some sort of lubricant (also a bit of a coolant) because the fine edge won't take much heat/friction. Light oil seems to work better for the really fine cuts. But I use dark sulfer for heavier cuts on steel.
Fasttrack
10-25-2007, 07:24 PM
I generally find that a much higher rpm with a carbide insert with a pretty big radius (TMCT-32.5 ... yeah its the cheapo grizzly holders ... ) will clean it up to a pretty shiny finish. Well this is the generic cold rold from lowes - not sure about other stuff.
lane
10-25-2007, 07:42 PM
CRS 1018 machine over size and file and sand to size . You want good machined finish use 1020 hot roll and machine to size will weld good.1144 stress proof 12L14 will not weld 1215 can be welded.
tattoomike68
10-25-2007, 08:21 PM
LaSalle Stressproof comes in 1140 and 1144.
It is tough to weld but if you look at the rear spindle on a John Deere 6602 wheat combine there is a 2.250" SP spindle with parts welded to it.
GadgetBuilder
10-25-2007, 10:08 PM
Some steel is ornery, leaving a "mouse tongue" finish with normal tools. A tangential tool may be helpful, mainly because of the steep rake angle; I generally get a better finish with this tool, especially cutting left to right.
One further thing you might try is a "vertical shear tool" or "contrary finishing tool". This tool is peculiar in that it cuts on the vertical edge rather than a point so the height setting isn't important; you can change the height if one area becomes dull. Although it seldom needs sharpening because it is only used for the final pass or two. It is truly a finishing tool, max depth of cut is probably 3 thou and the chips come off as wispy spirals rather than coils. It needs a fine feed, of course.
This tool is easy to grind so it's worth a try, see the file "Finish Tool.pdf" found here:
http://groups.yahoo.com/group/7x12minilathe/files/
(if you don't want to join that group, email me and I'll send a copy)
John
mechanicalmagic
10-25-2007, 10:58 PM
Just for a quick reference on metal properties, I go to:
http://www.mcmaster.com
and search for "alloy steel"
it's really quick, shows general properties in a simple format.
They also sell in 3' lengths, and stock a pretty good supply. I don't say they are cheap, but if I have to drive my truck 50 miles to pick up steel, it looks reasonable.
gzig5
10-26-2007, 11:33 AM
Tim,
When I get the phonographing effect you describe on my Craftsman lathe with mild steel, I have had good luck by reversing the feed direction on the last cut. I usually take 2-3 thou off with HSS bits for the finish cut and the carraige traveling under power towards the headstock. I disengage the halfnuts at end of cut, turn off the lathe, reverse the tumbeler lever so the carraige goes towards the tailstock, turn on the lathe and then engage the halfnuts. This is done without touching the depth of cut. Doing this seems to take the "threads" off because the carriage is being pushed by the other side of the lead screw and is not in the same position relative to the work and the tool takes off the high spots.
The other option is leaving a couple thou to file or sand down.
Greg
cybor462
10-26-2007, 01:25 PM
cut much 1018 and find as other said, carbide with a decent radius and fast spindle speeds with a slower feed. Must use coolant, I use flood and always get a mirror finish.
Tool must be on center, and yes I use Grizz cheapo holders with positive rake. Thier carbide is also C2 which is not the best but with a decent radius it does well.
Spin Doctor
10-26-2007, 06:05 PM
I've usually found that with 1018 moderate top rake of about 5 to 7 degrees that slopes away from the direction of cut and the rear of the lathe combined with a tool nose radius of .05 to .1" and a moderate feed and speed works quite well as long as cutting fluid is used. It won't be as good a finish as ground but then 1018 doesn't grind that well anyways. Another option is to take a facing tool that is ground with no tool nose radius and turn it upside down and use it as ascraping tool with the edge between the side and end clearances being used as the cutting edge. That one I got from Home Shop Machinist years ago. We used to have to turn bearing diameters on large shafts for presses and sometimes we had to use that trick to get finished size and the surface finish we wanted. Plus aside from its machining characteristics I fail to see the almost mythical status that 1144 seems to hold in the HSM community. Its' sulfur content alone is enough to make me think twice as it does not lend itself to good welding applications. IMO 4140, especially 4140 TG&P is a far better material in almost any application that would see either 1018 or 1144. Just my $.02 so take it for what it is worth.
h12721
10-26-2007, 10:22 PM
<<<<CRS 1018 machine over size and file and sand to size . You want good machined finish use 1020 hot roll and machine to size will weld good.1144 stress proof 12L14 will not weld 1215 can be welded.>>>>
Can you silver solder or braze 12L14?
Hilmar
dp
10-26-2007, 10:26 PM
I have a tangential tool I made for my shaper that I tried out on my lathe with 1018 in the chuck and it didn't do all that well. Better than what I had but it still left rings here and there. I also file and sand to fit and finish.
h12721
10-27-2007, 11:31 AM
[QUOTE=h12721]<<<<CRS 1018 machine over size and file and sand to size . You want good machined finish use 1020 hot roll and machine to size will weld good.1144 stress proof 12L14 will not weld 1215 can be welded.>>>>
Hilmar
dp
10-27-2007, 03:16 PM
Found an interesting video at youtube that shows a microscopic view of the cutting process and a (very) brief explanation of finish:
http://www.youtube.com/watch?v=86-xKFbdnOo
