View Full Version : Emco FB-2 Adapter
louosten
11-02-2007, 01:37 PM
Hello;
I was wondering if anyone had built or considered building an adapter table for the FB-2 milling head for the Super 11? The factory model tables are either non-existent or priced out of reason. I noticed that Grizzly and other suppliers have X-Y tables that you can buy separately, but the FB-2 would have to be bolted to an adaptor that was stout enough to support it vertically as well as in perfect alignment with the horizontal table used.
L.O.
NickH
11-05-2007, 11:14 AM
You mean like this?
http://i135.photobucket.com/albums/q158/magicniner/TufnolGearCutting.jpg
http://i135.photobucket.com/albums/q158/magicniner/DSC00775.jpg
Regards,
Nick
louosten
11-05-2007, 06:30 PM
Hello Nick;
Yes, like that, only I can't see any of your handiwork.....would it be too much trouble to post a disassembled picture of only the milling head and base, then comment on the x-y table you used? Thanks in advance.
L.O.
NickH
11-06-2007, 07:35 PM
Can't give any shots in bits as I just built it without taking photos but I can give you an idea how it fits together, it's a mixture of good luck scavenging, having the right tools around when I needed them and knowing a good new & used engineering equipment supplier.
I found several feet of this one day whilst scavenging the local scrap dealer's Aluminium corner -
http://i135.photobucket.com/albums/q158/magicniner/PICT0540.jpg
I didn't have a plan for it at the time but it sure looked handy for something!
A few months later I found the milling head & column in a crate at the back of the engineering shop's store and bought it planning to fit it at the back of my Myford Super 7's bed like an Emco, when I got it home it was too big & way too good for that so I looked around & saw the ally t-section.
Bored a hole to let the column drop in -
(you can see the collar retaining bolts in this shot too, along with some of the DRO fittings)
http://i135.photobucket.com/albums/q158/magicniner/PICT0542.jpg
Made a spilt s/s collar to clamp tight on the column
http://i135.photobucket.com/albums/q158/magicniner/PICT0543.jpg
Made & fitted rear & front plates for the base, this is the front, rear is the same, screws are M12 X 75
http://i135.photobucket.com/albums/q158/magicniner/PICT0545.jpg
This is the first table I used, mounted on my huge floor standing Mill Drill that I did the work on, it's really a coordinate drilling table and is too tall with too narrow ways for serious milling, but it was a start -
http://i135.photobucket.com/albums/q158/magicniner/PICT0546.jpg
The new table is half the height with ways almost twice as wide, can't find any more info than this,
http://i135.photobucket.com/albums/q158/magicniner/PICT0544.jpg
I trammed the table to the column, shimming under the table to get it within .001" over 200mm on a square clamped to the table, then trammed the head to the table.
It's a metric table with 4mm pitch screws, adjustable twin ball races at the handles and 300 X 300 approximate travel.
This is the new primary driven gear I made on the FB-2
with it running the first gear I made for it on the Mill Drill.
And here I'm making use of the Y travel to allow high speed work with a RotoZip mounted in front of the head on an adaptor plate
On that shot you can also see the Siemens Micromaster Inverter VFD which drives the 3 phase motor.
I'm planning sides & cross bracing for the base but I'm not having rigidity problems yet, even with the occasional setup that's cutting a foot above the table,
Regards,
Nick
louosten
11-06-2007, 09:02 PM
Thanks, Nick.......your pics are a good start for some planning. It appears that your setup is working well. I appreciate your work in getting this explanation out to me, and others.
L.O.
oldtiffie
11-06-2007, 09:38 PM
You mean like this?
Regards,
Nick
Hi Nick.
Don't want to hi-jack this thread.
Can you tell me what the material is that you are cutting those gears from in the first pic. please?
I notice that the title says "Tufnol" which is as I recall it (at long last!!) - is this still the case?
I have been looking for that or a board very similar to that for a long time. I could not remember its name until I saw your post and pic.
If it is what I hope it is, it is used for mounting/backing boards in electrical switch boards and is a good electrical insulator as well as very machinable, does not delaminate and can be brought up to a good polished finish. It made very serviceable gears as well.
Manufacturer/source details will be appreciated as well as I can then start to chase it in Australia or import a bit of it if needs be.
OK fellas - sorry for the interruption - now back to the topic of the thread.
[Edit 1]
Found tufnol at:
Google:
http://www.google.com.au/search?hl=en&q=tufnol&btnG=Google+Search&meta=cr%3DcountryAU
Australia
http://www.ceaco.com.au/tufnol.html
Exactly what was wanted - thanks.
[End Edit1]
OK fellas - sorry for the interruption again - now back to the topic of the thread.
NickH
11-07-2007, 06:01 AM
Try an ebay search for Tufnol, that's where I picked this lot up, I got some nice round section for knife grips too,
Nick
