View Full Version : Can anyone identify the finish on this wire end ?
nheng
11-03-2007, 07:18 PM
This is a 1" long, 0.026" diameter ground wire for an oscilloscope probe. It appears to be bright finished stainless wire that has been sheared off on both ends. The end finish, however, has a very fine, polished appearance. Can anyone identify the finishing method (based on only the image, of course)? Is this an example of electropolishing? Den
http://img.photobucket.com/albums/v319/nheng/misc/z_ground_tip.jpg
heavysteamer
11-03-2007, 07:41 PM
I would expect silver plate.
11-04-2007, 09:40 PM
Electropolishing is a pretty simple process. I've been meaning to try it on aluminum. All you need is 85% phosphoric acid, a bit of battery acid and some plumbing antifreeze. The phosphoric acid can be bought at a greenhouse supplier, used for adjusting pH in growing solutions.
Here is some public info I found:
http://www.freepatentsonline.com/3970529.html
