View Full Version : Troyke R15 table
StutzSpec
11-08-2007, 10:25 AM
Is there a way to disengauge the gear so the table will freewheel? This would help with setup.
lazlo
11-08-2007, 10:47 AM
I don't have Troyke, but on my Yuasa rotab, which is very similar, the worm is cut eccentric to the handwheel shaft. So to disengage the worm, you rotate the whole worm/handwheel shaft.
Edit: from MorseTaper on PracticalMachnist, here's a scan of the worm adjustment instructions:
Adjustment procedure for Troyke Rotary Tables (http://home.comcast.net/~morsetaper2/bbs/troyke-adjustment.pdf)
Cross Sectioned Drawing of Troyke Rotary Tables (http://home.comcast.net/~morsetaper2/bbs/troyke-xsec.pdf)
Troyke Brochure Page 1 (http://home.comcast.net/~morsetaper2/bbs/troyke-1.pdf)
Troyke Brochure Page 2 (http://home.comcast.net/~morsetaper2/bbs/troyke-2.pdf)
Troyke Brochure Page 3 (http://home.comcast.net/~morsetaper2/bbs/troyke-3.pdf)
Troyke Brochure Page 4 (http://home.comcast.net/~morsetaper2/bbs/troyke-4.pdf)
Troyke Brochure Page 5 (http://home.comcast.net/~morsetaper2/bbs/troyke-5.pdf)
Troyke Brochure Page 6 (http://home.comcast.net/~morsetaper2/bbs/troyke-6.pdf)
Someone on the thread that Tiffie linked had suggested that the Yuasa was a copy of the Troyke, but if you look at the exploded parts diagram in the second PDF, it's an entirely different design.
oldtiffie
11-08-2007, 10:48 AM
Thanks StutzSpec
Try this recent thread or post to it to "bump it up" to the first page where it will be noticed again.
http://bbs.homeshopmachinist.net/showthread.php?t=26231
lazlo
11-08-2007, 11:41 AM
Tiffie, he's asking how to disengage the worm, not our opinion on import rotary tables ;)
BadDog
11-08-2007, 01:39 PM
On the U-15, which is what I have, you have a mechanism attahced to a separate hand wheel on the opposite side that drives a rocker that moves the worm out of engagement. On the R-15, it does not seem to have that. So perhaps it works as Lazlo suggests. I do have a smaller "Manex" 8" that works that way...
Boy, I wish I could find a DA-15, but those things don't seem to exists... :(
mudnducs
05-05-2017, 12:52 AM
Longest wait for a reply? Yes. Rotate the collar at the handwheel to the right. It will disengage the worm so you can rotate the table manually. Re-engaging the worm is simply the reverse.
