After several years of fighing holes drilled off center I am hoping to solve the problem of holes off center in lathe tailstock drill chuck.
The facts:
1. cant seem to line up tailstock when drill chuck is mounted.
2. round bar in drill chuck indicates increasing reading as I move away from tailstock.
3. indicator reading with bar in lathe chuck and drill chuck tightened on round bar. 2 different morse taper adapters show .020-.030 runout at end of adapter as it and chucks are all rotated together.
4. Chuck is Jacobs 33B with 3/8 24 tpi. Came from garage sale box.
would it be right to assume threaded portion of chuck is bent internally?
Can I just bore out to true up and rethread to 1/2 20 ?
Am I overlooking something else I should check first?
Help please
The facts:
Help please
